Front bump install
Discussion in 'Long Travel Suspension' started by Armament, Sep 7, 2019.
  1. Oct 27, 2020 at 10:36 AM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    I got these off locked off-road guy is telling me that I just weld them into the frame is that truee they the pin bumps D3C09AFA-97FD-4496-826D-DCD7DB43454B.jpg
  2. Oct 27, 2020 at 10:40 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The sleeves get welded to the frame - not the bumps.
  3. Oct 27, 2020 at 10:42 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Alright thank you
  4. Oct 27, 2020 at 10:43 AM
    Armament
    Armament [OP] Well-Known Member
    Nick
    Albuquerque, NM
    2012 Tacoma Double can 4wd
    Full Camburg LT front suspension, King coil overs, Rough Country spindles, King 2.5 reservoir rear shocks, OME Dakar spring packs, T100 E-locked rear axle, 35x12.5x17 tires, Fiberworx fenders and bedsides.
    It’s not “that” simple, but yes. I showed pictures of what’s involved...
  5. Oct 27, 2020 at 10:44 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    Well see how it goes never done these before
  6. Oct 27, 2020 at 10:46 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Where are you putting them - in front or in back? There's a part of the sleeve that holds them in place at the bottom - only weld the top part and stop when you get to the part that has a smaller inner diameter.
  7. Oct 27, 2020 at 10:53 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    It’s for the front
  8. Oct 27, 2020 at 10:54 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Installing them with a long travel kit? If so, which kit?
