front bumper adjustment...driver side to passenger side
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Jan 7, 2009.
  1. Jan 7, 2009 at 5:24 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    anyone ever adjusted/centered the front bumper on their first gen's?? i noticed the other day that my damn bumper was too far to the driver side, so i need to adjust it and slide it over some.
  2. Jan 7, 2009 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I did this on my 2000. I saw it was to far to one side, so I bought some washers, and shimed it until it was perfectly centered.
  3. Jan 7, 2009 at 5:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool. i havent looked at the mounts yet....too damn windy here, but im gonna do that this weekend...when i flip my damn shocks over!!:D:rolleyes:
  4. Jan 7, 2009 at 7:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    SSSHhhhhhh!!!! :spy:
  5. Jan 7, 2009 at 8:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....i know:rolleyes::eek:.....but i have come clean about it now!:D
  6. Jan 7, 2009 at 8:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    what did i miss?
    whats wrong with having the boot side up?
  7. Jan 7, 2009 at 8:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    eh...not alot.they are supposed to be boot down.........not hurting anything as is, but im gonna swap them the right way.
  8. Jan 7, 2009 at 8:06 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    ok...ive never noticed any ill effects from having them up
  9. Jan 7, 2009 at 8:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    me either...........ride has been great. i probably wont notice a difference myself, but im gonna do it and see. gotta get my new slotted rotors and hawk pads on too. my weekend will be busy if it aint rainy,windy and cold...............going back to look at that property too!!
  10. Jan 7, 2009 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, its because of your avitar. :p
  11. Jan 8, 2009 at 2:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok,back on topic of this thread.................looked under the truck today to see if i could see the bolts for the bumper to loosen and slide......didnt see any mounts that looked like they had sliding room. which mounts will be the ones i need to loosen for the adjustment??? any ideas?
  12. Jan 8, 2009 at 3:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, On mine, I removed the bumper, and repositioned it on the other side of the mounts, then used washers to move it one way or the other. You should be able to see the bumper mounts from under the truck.
  13. Jan 8, 2009 at 3:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok...went and looked again....looks like there may be a slight adjustment on the 2 main bars under there, but i need about 3/4 of an inch to the passenger side. i may have to unbolt the bumper and do as you did man. now that i got to looking at it...it looks ridiculous as hell(cant believe i just noticed a week or so ago:rolleyes:), so i gotta get it back even. im gonna crawl under there this wknd and see whats up!
  14. Jan 8, 2009 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats the same thing that happend with mine. GL.
  15. Jan 8, 2009 at 3:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thanks. all the bolts and nuts are rusted pretty good....looks fun!:eek::D
  16. Jan 8, 2009 at 3:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  17. Jan 8, 2009 at 3:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    already got it!
  18. Jan 10, 2009 at 3:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    got my bumper lined back up today.......took the brackets off.....they were bent a little, apparently where someone hit the side of the bumper. starightened the brackets out,then got the wifey to put some ass:D into the driver side to shift it a bit, then i shimmed with a couple of washers on the pass side between the bracket and frame..........tightened it all up...............looks alot better now! its almost perfectly even now.
    also...................got my rear shocks flipped the right way now too.
  19. Jan 10, 2009 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WTG on the bumper! :)
  20. Jan 10, 2009 at 5:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thanks man...............you give me the idea to shim with some washers! i drilled out 4 fender washers that i had, to fit those bolts, then put them between the bracket and frame on the passenger side!! now............it doesnt look retarded anymore!!:D
