front bumper crash bar?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xyourlocaldjx, May 29, 2014.
  1. May 29, 2014 at 4:12 PM
    xyourlocaldjx
    xyourlocaldjx [OP] Well-Known Member
    The bolts that hold the aluminium bumper behind the plastic bumper have been stripped. I tried to remove them with a clamp and also tried hammering. No luck. Anyone have any advice?
  2. May 29, 2014 at 9:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Stripped or is the head rounded off?
    Use a grinder and grind the heads off. Then you should be able to turn the remains out with vice grips or ...
  3. May 29, 2014 at 9:39 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    They are not bolts, they are studs.
  4. May 30, 2014 at 8:21 AM
    xyourlocaldjx
    Sorry I was vague. The Nuts come off , but the studs are a bit stripped. Are they welded onto the bracket?
  5. May 30, 2014 at 10:16 AM
    bullaculla
    Da big big island!
    I think they might be pressed in. I thought I saw splines on the body when I was installing my bumper. I'll take another look when I go out to my truck. If you see splines, they are pressed in.
  6. Jun 14, 2014 at 9:14 PM
    xyourlocaldjx
    i dont think they're splines? the plate looks a bit too thin for something to be pressed in. i think they may have spot welded it in place. god i hope not
  7. Jun 14, 2014 at 11:42 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Factory studs are spot welded to the plate. If you want to remove one, hit it back and forth a few times with a dead blow or rubber mallet. They seem to snap the spot welds pretty easy that way. Then just run a regular bolt in its place if you can't weld a new stud in
  8. Jun 28, 2014 at 5:11 PM
    xyourlocaldjx
    dont think this will work on the 2005 and up models. seems like the whole back part is welded on. when i tried knocking it back and forth, the whole "sheet" metal it was welded to kept bending.
