Front bumper install issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Perfuseme, Mar 9, 2017.
  1. Mar 9, 2017 at 5:59 PM
    Perfuseme
    Perfuseme [OP] Well-Known Member
    Rick
    Installed new pelfrey bumper and the alignment looks off. I haven't seen another in person so maybe this is correct but I don't suspect so.
    The height adjustment is as high as I can get it and all blots are tightened down. The driver side had some damage, hence the new bumper but it actually looks better aligned than the passenger side. Front mating looks ok.
  2. Mar 9, 2017 at 7:43 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    You have to shim the bumper for alignment. Mine was the same way.
  3. Mar 9, 2017 at 7:44 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Mar 9, 2017 at 8:43 PM
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    Mine did that as well. Add flat washers to one side and it should even out. Make sure its Grade 8 washers.
  5. Mar 9, 2017 at 8:49 PM
    Boozng
    Dave
    Did your crash bar get damaged on the driver side in the accident? That might have changed the alignment. If you add a washer onto the driver side bolts, it'll push the bumper out a little more and look more even.
  6. Mar 10, 2017 at 4:45 AM
    Perfuseme
    Rick
    I don't think so, most everything looked OK under there. Even the flimsy aluminum bracketry. I had hit a tire and it did mostly cosmetic damage best I can tell.
  7. Mar 10, 2017 at 4:46 AM
    Perfuseme
    Rick
    I did talk to pelfrey and they suggest mostly what you guys have said. Il run through some of this over the weekend and see how goes.
  8. Mar 10, 2017 at 5:50 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    The driver's side looks too high in the pic showing the fender. Should be close to 1/2" clearance between the bumper and the fender. The cab will move quite a bit, and will contact the bumper if too close.
    Bruce988jl likes this.
  9. Mar 10, 2017 at 6:07 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    You'll want some gap with the bumper for flex.
    What size are those studs that the bumper bolts up to?
  10. Mar 10, 2017 at 7:51 AM
    Pigpen
    Dan
    Northwest Montana
    It looks like the whole front of the fender was pulled down when you hit the tire. There's a big gap between the headlight and the hood, as well as the hood and the front of the fender.
  11. Mar 10, 2017 at 8:04 AM
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    They suggested to shim the bumper? Where would you shim it? I could see shimming if the bumper was closer IN on one side, but OP is having issues with one side being higher.
    In any case, 1/2" gap on both sides is called for in the install instructions due to body flex.
    Loosen the bolts on the side that is too high, tap down gently, and retighten the bolts.
    Also, make sure the bottom of the bumper sitting on the bolts is sitting flush. The first time I put my bumper on there was a gap near the bottom. This should go away when you tighten the bolts, but if it was off, it may not.
  12. Mar 10, 2017 at 8:06 AM
    kitsym
    Portland, OR
    He's missing the snap-in trim piece below the headlight. And it looks like the headlight was tweaked up causing the gap above the light. Possibly broke the retaining clip to the grill? There is a little bolt (or body pin.. can't recall).
  13. Mar 10, 2017 at 10:17 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    We are working on solving this. There are several factors that may be affecting the fitment. We will ensure everything is dialed in when its all said and done. Rick has a game plan for the weekend to make necessary adjustments.
  14. Mar 10, 2017 at 3:14 PM
    Perfuseme
    Rick
    Yes the headlight is all jacked up and half of it securing point are broken. Most of the gaps you see are because the headlight is barely in. Iv got another set I'm doing retros on.
    I'm going to play with it this weekend. The passenger side is too low for sure. The driver side could be lower but that doesn't fix the passenger side.
  15. Mar 10, 2017 at 3:15 PM
    Perfuseme
    Rick
    Yes, that is missing and makes that side look all sorts of crazy
  16. Mar 10, 2017 at 3:31 PM
    Perfuseme
    Rick
    I do have to remind everyone this is, at this point, an installation issue. The bumper itself kicks ass tho my little girl doesn't like it.
    It seems to angle down slightly as it travels to rear of car as well. I expect a shim on the top mounting stud will allow this to suck up some.
  17. Mar 10, 2017 at 3:33 PM
    kitsym
    Portland, OR
    Just FYI: You can pull those wings off. It's 1 bolt on the underside.
    Naveronski likes this.
