Front Bumpstop loose. What tool to tighten it?
Discussion in 'Suspension' started by Oscarbob, Aug 24, 2011.
  1. Aug 24, 2011 at 9:18 PM
    Oscarbob
    Oscarbob [OP] Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    So I discovered my driver's side bump stop was loose. Hanging about 1/2" or so lower than it should be.
    I'm able to sneak an 18MM wrench on the nut above it and have it brace against the metal structure around it. I hand tightened the bumpstop until my neck made a weird noise. But now it's still just hanging there rattling around about 3/8" left to go.
    I tried a plumbers wrench, didn't work. Largest set of channel locks I had could only grasp the rubber. I tried tightening it with those but the rubber started to stress a bit and don't want to tear it up. It looks like a huge socket could fit on there but it's bigger than the 2" one I had sooo...
    Any ideas how to tighten it up?
    PS. I did soak the bolt and nut with some WD-40, I didn't have an PB Baster or the like at the time.
  2. Aug 26, 2011 at 3:42 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I used really big channel locks to grab the metal above the rubber. You may need to get some bigger channel locks.
    Unfortunatly if you bottomed out on the bump stops while they were loose it may have bent the stud.
    I highly recommend the Wheelers Super bumps (even for stock trucks). Look at this video.
  3. Aug 27, 2011 at 9:19 AM
    Oscarbob
    Bob
    Central New York
    Well I probably bent the stud I think because I definitely flexed that tire out completely on a stump. I'll probably just order the wheeler's...
