Front caliper problem
Discussion in 'Technical Chat' started by stuntmanmike, Jun 20, 2009.
  1. Jun 20, 2009 at 9:09 AM
    stuntmanmike
    stuntmanmike [OP] Member
    3" lift
    I'm trying to replace the pads on the front of my 2004 tacoma and the pins that hold the pads in the caliper are seized. I tried using PB blaster and hammering them out but its not working. Anyone have any solutions?
  2. Jun 20, 2009 at 9:14 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i had that problem when i did mine a while back too. let the pb blaster sit for a bit, then use a pair of needle nose pliers to kinda squeeze the first bit of the pin, then it should break loose. after you get them out....use steel wool on them to clean off the rust.
  3. Jun 20, 2009 at 9:16 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You're gonna have to work those pins out. Like will said, PB blaster is your friend. Can you tap them out with a punch?
  4. Jun 20, 2009 at 9:18 AM
    stuntmanmike
    3" lift
    I can't get a grip on the pins with the needle nose pliers and the pins wont budge if i try to tap them out
  5. Jun 20, 2009 at 9:49 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try using a pair of slip joint pliers...big ones if you have them,one end on the pin...other end on the caliper and see if you can push them out that way.
  6. Jul 19, 2009 at 12:04 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Reviving this thread due to .I HATE THOSE PINS;)
    I went to do the brakes today and THOSE pins were a PIA....
    Even after pre-soaking them last weekend,they still did not move and being there are boots plus pistons in there...Heat wrench stayed packed...
    My answer; 1) cold chiseled the end off 2) center punched the end and drilled through the inside hole 3) long prick punch and small ball pean did the rest 4) wire brushed the holes [5)trip to advance auto for new pins;$7.49 ] 6) pull old pads and shims 7) clean all old parts and slides
    8) install new pads with old shims 9) install new pins and "Shake" clip,plus pin clip...check under hood for brake fluid level,then push pedal to seat pads 10) install tires and test drive work....
    Considering there are "young'ns" reading this I left out the beverage consumption;),cussing and Moms laughter:D:D..she gave me the ride to "Parts store":rolleyes:;)
    #5 can be a fore thought (Buy the pins when you buy your parts;) ) and save yourself some time...
    The only other problem that occured,my "Need" to "MOD" my truck...clean and paint all chassis parts not replaced during "frame swap"( 4-5 cans black paint) paint cailpers & drums green to match cab colors( 2-3 cans paint) and actually find time to buy my TOOLBOX;):cool:..
    This place is addictive BUT a great knowledge base too :cool:
    Snoope back quiet
  7. Jul 19, 2009 at 12:10 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    knock on wood, as far as i know i still have my original pins from toyota. I havent had any problems with them.
  8. Jul 19, 2009 at 1:25 PM
    snoope
    Wildjerseyfirefighter,
    That was my problem...those were the originals......1st set of brakes in 7 years( 44,000 miles) and the oems said f/u.....one of the 4 came out,2 came out after drilling and the 4th looked more like a pretzel........best thing is,those were cheap parts to replace , the calipers and rotors were fine....
    Snoope
