front calipers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nirango kid, May 22, 2025 at 4:05 AM.
  1. May 22, 2025 at 4:05 AM
    Nirango kid
    Nirango kid [OP] Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Hi all just wondering if any of you had to replace the front calipers on your truck and at what mileage.
    Just had my truck maintenance done and was told front right caliper needs to be replace at 75,000 KM ( 46,000 miles ) is this normal. I have owned previous Tacoma and don't recall ever changing calipers. Just wondering is this normal or a defect. Thanks for any reasonable answer.
  2. May 22, 2025 at 4:08 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    your missing an important part of this equation in your post....
    why are they telling you the caliper needs replacing????
    also did you take it to them to checkout a specific concern / symptom?
    or was it just a recc off an inspection?
  3. May 22, 2025 at 4:34 AM
    Nirango kid
    Gilles
    Ontario
    It is part of vehicle maintenance brake inspection. I have been taking my vehicle at this place since new and they are honest family owned business. So if they say I need a caliper then I do.
  4. May 22, 2025 at 4:37 AM
    slater
    San Diego
    ok!
    But why are they claiming you need a caliper?
    What are they saying is wrong with it?
    Im not saying you dont, just trying to better understand what's wrong with this said caliper...
  5. May 22, 2025 at 4:39 AM
    Nirango kid
    Gilles
    Ontario
    I want to know if it is covered under the 30,000 km ( 3 year ) manufacturers warranty. Some components are covered beyond and would like to know what. I will find out today what the issue is with the caliper from my mechanic.
    thomasburk likes this.
  6. May 22, 2025 at 4:44 AM
    slater
    San Diego
    My guess would be that it most likely is covered under 3/36 if it was leaking or binding....
    But if he wants to replace it cuz its rusting, assuming it snows in Canada, would not be covered......
    If he was truly an honest mechanic he should know the general ins & outs of bumper to bumper warranties...
    "Hey I found this wrong with your car, chances are you still fall under manf warranty, give them a call, if its not, ill give you an estimate" so on...
    MR E30, DavesSR5 and t0p_d0g like this.
  7. May 22, 2025 at 4:46 AM
    slater
    San Diego
    If your truck is a 21 as it states in your sig, youre out of 3 years, warranty coverage ends at which ever comes first,
  8. May 22, 2025 at 5:12 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wouldn’t say caliper issues are super common, but they do happen and most of the time the problematic piston is the inner lower piston. I wish Toyota just used normal floating calipers.
  9. May 22, 2025 at 6:51 AM
    Devolve
    Devolve Member
    Ontario, Canada
    2019 Cement DCLB
    I see you're in Ontario too, might be rusted out piston causing uneven wear. Maybe they tried to bleed the brakes and the bleeder was stuck?
  10. May 22, 2025 at 7:22 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe uneven pad wear, maybe a stuck bleeder screw. Did they say why?
    In my opinion calipers should be replaced in pairs though, doing a single side opens up the possibly of uneven braking side to side. Not a huge concern but something to think about
    46k is pretty early to need calipers unless you live in the rust belt
  11. May 22, 2025 at 1:26 PM
    Nirango kid
    Gilles
    Ontario
    Thanks everyone for your replies. I talked to the mechanic and he said the caliper pistons ( 2 ) where ceased on both front calipers. Make the story short I have replaced both calipers, pads and rotors. Now it is like new again.
    Did not bother trying to find out if they were under warranty which some of you have mentioned 3 years or 36,000 and I am passed that.
    b_r_o likes this.
  12. May 22, 2025 at 1:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Most manufacturers exclude brakes from warranty because they're a wear item and more dependent on driver habit. At least for the brake components down at the wheels
    kahanabob likes this.
  13. May 22, 2025 at 3:18 PM
    slater
    San Diego
    Brake pads are wear item, but in some situations can get covered under 12/12,
    also in certain situation you can get pads covered if you code it to another component, cause & effect...
    if calipers are defective, they would be covered under Toyotas base bumper to bumper warranty...
    Canada, snow state, road salt, seized pistons, assuming rusty, wouldnt hold my breath....
    I couldn't tell you what techs do in snowy states where rust is an issue, ide guess they dont turn a blind eye & push it through as likelihood of toyota calling the part back & inspecting it is high, safety item.....
  14. May 22, 2025 at 5:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    In salty environments like ours, you need to "service" the brakes every two years or so. Basically clean up and grease the pad backing plate, shims, and retention pins.
    TacoDell60 likes this.
  15. May 23, 2025 at 9:00 AM
    TacoDell60
    TacoDell60 Well-Known Member
    I have a very rust free and very well maintained 2016, and needed to replace my driver's side calliper last week at 81,000 miles (130,000 km) because one of the pistons became stuck and would not retract when letting off the brake pedal. I did not replace the passenger-side calliper since it is rust free and clean/greased and operates normally.
    Replaced with a brand new oem Toyota calliper. Forgot how shiny they are when brand new.
    I've actually never had a calliper seize on any vehicle ever before this. Not sure what caused it, but it does happen.
