Front Camera & Anytime Back Up Camera Install Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by runnin4tacos, Feb 12, 2019.
  1. Feb 12, 2019 at 11:19 AM
    runnin4tacos
    runnin4tacos [OP] Well-Known Member Vendor
    Tuan
    Denver, Colorado
    2017 Cement TRD Pro, 2024 TRD Off Road
    Hey guys,
    I just did a video on adding a front camera and added the harness to allow me to use the front and rear camera anytime with a push of a button. So, of course, I want to share this with you guys so if you guys are interested in doing this mod, consider checking out the video.
    I am using the full kit from AnytimeBackupCamera.com ($100) with a $40 camera that I got on Amazon. There are a few options when it comes to the camera and I have the options listed below the YouTube video description.
    I did this mod because I go off road a lot with just the wife and dogs, so I do NOT have a good spotter when I go with just them. Some parts can be pretty worrisome as I can't see in front of me when I am angled up, so having a front camera definitely helps out a lot. Also, I sometimes use it in tight parking spots and in my garage when I have a lot of stuff in front of me.
    I was told that I could use the power from the back of the radio to power the camera as well but I didn't know that when making the video, so if you'd like to do it that way, more power to you. If you guys like the video, consider subscribing as I make weekly videos.
    Here is is:
    https://youtu.be/dD5ANbp4aVo
  2. Feb 12, 2019 at 12:59 PM
    trayscool
    trayscool Well-Known Member
    Travis
    Long Beach
    2018 TRD OR
    Thats awesome, nice vid
  3. Feb 12, 2019 at 1:19 PM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Nice work
  4. Feb 12, 2019 at 1:51 PM
    buntcake
    buntcake Well-Known Member
    Booboo
    2020 TRD OR Cement
    I bought this a while ago and have been putting off install, thanks for the how-to!
  5. Feb 12, 2019 at 7:22 PM
    Surferboy120
    Surferboy120 Well-Known Member
    Nice video thanks for putting it together way easier than I thought. Unfortunately they dont seem to have anymore kits so I will have to wait.
  6. Mar 12, 2019 at 8:33 AM
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    Just got one of these. Thanks for the directions.
  7. Mar 12, 2019 at 8:34 AM
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    If only they would ship the harness... Been on "preorder" for weeks now.
  8. Mar 12, 2019 at 8:58 AM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    Nice video
  9. Apr 7, 2019 at 10:53 AM
    DocGreyPilgrim
    DocGreyPilgrim New Member
    2019 TRD Offroad
    This video is very helpful. Thanks.
    I have an issue hopefully someone can help with. Is there a way to wire this up so that you only have a front camera switch?
    I haven’t been able to find a thread by anyone who only installed a front camera switch. I’ve gotten to the point where the harness is installed and the camera works, but the front camera switch only works if I put it in reverse. So without the switch pressed it shows the regular backup camera, then if I push the switch while in reverse it shows the front. The switch won’t override the screen if I’m in drive or park though.
    I’m assuming it has something to do with the orange wire from the kit that I didn’t hook up. I’m just not sure. My switch is from aironboard, and has a black, green, red, and blue wire. I wanted one that fit in the tall blank I had on the left side under the cubby (only empty switch I had).
  10. May 26, 2019 at 5:46 PM
    krazycoble
    krazycoble Well-Known Member
    Long Beach, CA
    2017 TRD 4x4 Sport DCSB
    Hello! I just installed my anytime front and rear camera. The camera and switch work great. However, my check engine light and trac off light are on. Any idea what I might have did wrong?
  11. Jun 8, 2019 at 1:15 PM
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    Prices went WAY UP since the OP... Anyone got other sources for the switch or harnesses?
