Front coil OME 880 or 881
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrispchicken9, Jan 1, 2019.
  1. Jan 1, 2019 at 11:56 AM
    chrispchicken9
    chrispchicken9 [OP] Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Looking into getting front coils for ‘04 V6 Pre Runner paired with Bilstiens 5100 up front. Coils set to bottom notch.
    Was originally leaning toward OME 881 coils as they’re a bit stiffer than 880, but it’s a Pre Runner so there’s no front dif, so would it be too stiff and jack the front up super high?
    Running stock front bumper with no winch or anything like that. Bone stock.
    Looking to get around 1.5” - 2” max lift. For pre runner would 880 be better suited to achieve 1.5” - 2.0” lift? Or is the 880 just too light of a spring?
    Anyone with experience with either of these setups? Preferably pre runner but any info helps :) thanks in advance
  2. Jan 1, 2019 at 4:07 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    I have the OME 881s set on the middle setting and have a front differential and a 100lb ARB bar, no winch.
    Almost 3" of lift in the front.
    Keep in mind that this is a single cab.
    Hope that info helps...
  3. Jan 2, 2019 at 7:17 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    I was running 883 up front before I converted my prerunner to 4x4. The 3.4 is heavy, my ride wasnt noticeably different before and after, ride height dropped 1/2 inch after 4x4 swap. 5100 should be st at lowest position unless using stock springs. My vote would be 882(same spring rate as 881 just longer) set at zero
    Hamer95USA likes this.
