Front Coil Spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmdixon392, Nov 28, 2011.
  1. Nov 28, 2011 at 11:44 AM
    jmdixon392
    jmdixon392 [OP] Member
    Statesboro,Georgia
    08 PreRunner TRD Sport
    33" Tires, Off-Road Lights, Dual Exhaust, Aftermarket Audio
    I want to put on a 1.5' Coil Spacer to my truck. I hear that a 1" Day Star gives a 2" look. What would be the best product to use for a even level or to have the front to sit a little higher than the rear?
  2. Nov 28, 2011 at 11:54 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Avoid spacer lifts. Bad ride & broken parts
  3. Nov 28, 2011 at 11:57 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    why do you want the front to be higher than the rear? (If I may ask)
    cause of you add a load to the bed your truck will be very nose high.
    but as far as the spacers, all spacers are generally the same...just a hunk of metal that lifts the front of the truck; but we try to steer people away from them because they give a pretty harsh ride and wear out suspension components.
    try research some bilstein 5100's for a cheap leveling kit
  4. Nov 28, 2011 at 12:05 PM
    jmdixon392
    Statesboro,Georgia
    Well i want to make the truck sit level for relatively cheap but effective. I have an extended warranty on the truck and if I did a full body level it would void every bit of the warranty. I asked the dealership about the spacers and they said if anything component on the front end with or without the spacer would be voided due to "wear and tear".
  5. Nov 28, 2011 at 12:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    If you lift the truck but have a warranty, the dealership still covers you unless they can prove that an aftermarket product has caused a failure.
    I'm confused as to the point of that post though; if you asked the dealership about the spacers and they said no (as far as the warranty) are you still interested in leveling the truck?
    Even so, look at 5100s rather than spacers.
  6. Nov 28, 2011 at 12:16 PM
    jmdixon392
    Statesboro,Georgia
  7. Nov 28, 2011 at 12:19 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  8. Nov 28, 2011 at 12:24 PM
    jmdixon392
    Statesboro,Georgia
    ok. I see what you are talking about now. I didnt realize they were adjustable. Guess ill just have to look around for the cheapest price.
  9. Nov 28, 2011 at 12:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    the link I posted are the cheapest 5100's you can get, DSM also offers a discount to TW members that brings the price down even more
  10. Nov 28, 2011 at 12:30 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Be advised that the shocks themselves do not lift.
    They are directing you to a "Bilstein Lift" that uses a special shock body that allows the spring seat to be moved up to create lift.
  11. Nov 28, 2011 at 12:34 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    I just replaced my spacer lift with the 5100's.
    Here is why.
  12. Nov 28, 2011 at 12:39 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Kewell. But what were you doing when that happened, and are 5100s up to the job?
  13. Nov 28, 2011 at 12:44 PM
    jammdogg
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    Offroading of course! :D
    Hit a rock on the way up to the trail, then normal trail stuff. Nothing overboard, as it is my daily driver. I had always wanted to replace the spacers, just needed a reason. I knew I had blown the shock, but had no idea it had broken in two.
    The 5100 gave me the same amount of lift, and I will not have to deal with the shocks bottoming out on the trail, which is an issue I had with the spacers.
  14. Nov 28, 2011 at 1:23 PM
    jflan
    Vancouver, WA
    Just wanted to dispel that all-to-common myth that shocks can provide lift.
    Didn't see anything that clarified that.
    Edit:
    Air shocks excepted.
