Front coil spring broke, what should I replace it with?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thadeusmax, Sep 12, 2018.
  1. Sep 12, 2018 at 4:16 PM
    thadeusmax
    thadeusmax [OP] Member
    Hi All,
    While driving home today I heard and felt a loud "CLUNK" in the front end. Once I got home I found that my front drivers coil spring had completely snapped, as you can see in the picture below.
    Needless to say I need to find a replacement. Does anyone have a recommendation on a specific coil (not the full assembly) to replace these with? I say not the full assembly because I JUST replaced the Bilstein shocks this year, so I'd rather avoid that extra cost.
    Some background on the truck:
    2011 4x4 TRD Pro Access Cab
    Springs are Toytec/Eibach 112-620 (About 1.5 inches of lift)
    Shocks are Bilstein 5100's
    I'd like to keep 1-2 inches of lift in the front end, but I can accomplish that either with the springs or by adjusting the Bilsteins.
    Also, has anyone else experienced this? The truck only has about 68K miles, so I wouldn't expect these to fail so soon. I don't beat on the truck either, just VERY light off road travel.
    Thank you in advance for your help!
  2. Sep 12, 2018 at 4:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    OME 884 coils would get you about 2.25" of lift. If you want less and want to remain around 1"-1.5" get OME 883
    08TacoTrD likes this.
  3. Sep 12, 2018 at 4:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Looks like its corrosion, not wear. I would just order the same spring and maybe spray it was some anti-rust wax and make sure to wash more often.
  4. Sep 12, 2018 at 4:21 PM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
  5. Sep 12, 2018 at 7:21 PM
    Muddinfun
    Muddinfun Well-Known Member
  6. Sep 13, 2018 at 6:40 AM
    thadeusmax
    Thanks all. I went with the OME 883s based on your recommendations.
    Muddinfun, I definitely plan to reach out to Eibach, because I wouldn't expect that amount of rust to cause a failure like that.
    EatSleepTacos likes this.
  7. Sep 13, 2018 at 6:57 AM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    How many miles on it?
  8. Sep 13, 2018 at 7:47 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I’m surprised with an EIBACH/TOYTEC coil, did you buy them used? If you bought them new, what’s the mileage on them?
  9. Sep 13, 2018 at 9:03 AM
    thadeusmax
    I actually bought the truck used, with them already installed, with around 57K miles on the truck. I put another 10K miles on before this one failed.
    So for all I know the previous owner beat these up pretty good, but it still seems like an early failure.
  10. Sep 13, 2018 at 9:06 AM
    Muddinfun
    Unfortunately that falls under exclusion f.
  11. Sep 13, 2018 at 3:48 PM
    SWB Tacoma
    Arkansas
    Looks like fatigue to me. I would call them.
