Front Coil Spring Isolators {2GEN}
Discussion in 'Suspension' started by 2010THRASHER, Sep 21, 2013.
  1. Sep 21, 2013 at 9:17 AM
    2010THRASHER
    2010THRASHER [OP] Member
    COEUR D' ALENE IDAHO
    2010 4X4
    I have a revtek kit on my truck.Soon I will be swapping it out for 5100s w/springs.I'll be buying new strut mounts....
    how-ever the Monroe strut mounts don't come with an isolators.
    I can't seem to track down the isolators, any advice to part # or were to buy would be greatly appreciated...
  2. Sep 21, 2013 at 11:17 AM
    Digger2
    Digger2 Well-Known Member
    Ontario, Canada
    '08 Double Cab TRD
    ARB Deluxe bumper, Full OME HD lift kit with Dakars. Frame welded Crew Fab DOM rock rails,Custom full skid plates, tow points,Cab mount chop, 265/70R17 Duratracs, weather tech mats.Coming soon Camburg BJ UCA's, Warn ??? winch
    I was in the same boat. Member pave mobile gave me the info of energy suspensions part #9.6104 would work. So I bought them and they worked fine. If u need the rubber bushings for top of strut just get the kit from wheelers offroad. Don't go to dealer as they don't sell one of the 2 bushings that go on either side of top plate. The Toyota top plate comes with one of the bushings and u can't get it separately. Hope this helps.
  3. Sep 21, 2013 at 12:20 PM
    2010THRASHER
    2010 4X4
    thank's a bunch man...anything else you think I need besides :
    (2)Monroe strut mounts
    (2)energy suspensions part #9.6104
    and that strut kit from wheeler's ?
    I won't be taking apart these crappy revtek spacers/springs/strut that I'm currently running
  4. Sep 21, 2013 at 12:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Did you buy the 5100s already? If you buy the 5100s and springs from Wheelers, they can supply the top hat and all relevant parts and assemble them for $158: (OME shocks shown)
  5. Sep 21, 2013 at 12:39 PM
    2010THRASHER
    2010 4X4
    Sound's like that might be the way to go ^^ was gonna buy the shocks soon from down-south and springs from toytec ~.~
    trying to keep it cheap I'll check them out thanks for the quick response.
  6. Sep 21, 2013 at 12:45 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Toytec also offers assembly but IDK if they only offer it on complete lifts.
  7. Sep 21, 2013 at 12:52 PM
    KenLyns
    Belly of the Beast
  8. Sep 21, 2013 at 1:04 PM
    2010THRASHER
    2010 4X4
    And what's the word on this rancho set up... as far as life and ride quality I don't want to sacrifice those things for a few dollars.....
    I don't need to have them assembled I just need the missing pieces !!
  9. Sep 21, 2013 at 6:21 PM
    Digger2
    Ontario, Canada
    '08 Double Cab TRD
    Nope I think that's it. The wheelers kit comes with the 2 steel washers,2 bushings x 2. The order is washer,rubber bushing,top hat, rubber bushing, washer, nut. As a another member had mentioned you may be able to buy your stuff pre-assembled to which maybe easier. Here's a link with all the misc parts from Wheelers Hope that helps.
  10. Sep 21, 2013 at 7:45 PM
    2010THRASHER
    2010 4X4
    Thanks for the info =D as the misc part's are adding up having them assembled is a more viable option....
