Front Coil Spring Isolators
Discussion in 'Suspension' started by pavemobile, Sep 21, 2011.
  1. Sep 21, 2011 at 3:49 PM
    pavemobile
    pavemobile [OP] Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    Does anyone know a good source for the front upper coil spring isolators, either stock rubber or urethane? Can't seem to find a part number for stock. These are for an '09 TRD Sport PreRunner - thanks
  2. Sep 24, 2011 at 5:01 AM
    pavemobile
    K&N Intake
    Anyone?
    Trying to buildup a set of Bilstein 5100's w/springs and have a plug and play unit for each side.
    Any advice, part #'s, experience greatly appreciated. Thanks
  3. Sep 24, 2011 at 6:15 AM
    saugus
    saugus Well-Known Member
  4. Sep 24, 2011 at 7:06 AM
    pavemobile
    K&N Intake
    I have used Toyota Parts Zone several times with good luck but they removed their exploded view drawings so I checked a couple of other Toyota sites and my FSM for the breakdown but they don't show the insulator as a sub assembly part...don't show it at all. I don't have a problem breaking down the old strut assembly and re-using but if I could find the insulator I would have a built up replacement unit and probably put the old assemblies up for sale here.
    The aftermarket upper mounts, like the Monroe don't come with an isolator, I had a buddy check a box at our Advance Auto Parts store. Anyway, the quest continues.
  5. Sep 24, 2011 at 7:23 AM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    what are you looking for exactly? the right and left spring?
  6. Sep 24, 2011 at 11:07 AM
    pavemobile
    K&N Intake
    I am trying to find the rubber insulator/isolator that goes between the top of the front coil springs and the mount plate assembly that holds the strut/spring assembly together. Energy suspension makes some universal isolators but a person needs to know the external & internal dimensions. I was thinking if I could find a part number for OEM my problem would go away, I could use stock rubber or order a urethane pair and not have as much down time.
  7. Sep 24, 2011 at 11:22 AM
    saugus
  8. Sep 24, 2011 at 1:54 PM
    pavemobile
    K&N Intake
    The rubber part under 48603/48609, can't seem to get a sub assembly part number without buying the whole mount - 60 - 70 bucks each.
  9. Sep 25, 2011 at 5:29 AM
    pavemobile
    K&N Intake
    I took a set of springs this morning and measured all the dimensions I could think of and Energy Suspension part # 9.6104 seems to be the best match for my springs - '09 TRD Sport. Not sure about the Off-Road set. While they are not an exact match to OEM I'll post some pic's during R&R and buildup of the new set. The ES set has a flat pad for the upper end to rest on while OEM seems to have a small umbrella like outer lip - not big but it's there.
    set No. a B c D E F
  10. Nov 18, 2016 at 1:20 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Did these ES isolators work out ok for your '09?
  11. Nov 18, 2016 at 1:52 PM
    pavemobile
    K&N Intake
    They did. I reused them back in August when I replaced the shocks and they were unchanged. I just washed with soap and water and in they went. If you plan to keep your truck for a little while, I can vouch for money well spent. Enjoy!
  12. Nov 18, 2016 at 1:53 PM
    fishfinder
    fishfinder Whoever dies with the most toys wins
    Mikey
    Santa Barbara
    2015 MT DCLB
    CBI armor, Kings, 35s, Lockers
    How weird... I never heard of "coil spring isolators" until today over on @inv3ctiv3 's build, now I see this.
    Jim Bob likes this.
  13. Nov 18, 2016 at 2:02 PM
    fishfinder
    Mikey
    Santa Barbara
    2015 MT DCLB
    I see a lot of folks using zip ties... Mine don't squeak:notsure:
  14. Nov 18, 2016 at 2:12 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2005 Tacoma TRD Off-Road DCSB
    ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
  15. Dec 23, 2016 at 1:18 AM
    Plan_C
    Plan_C Member
    The KYB part number is SM5413 for the front coil isolator's. This is for the 05-15 tacoma front coils. It is the same part Wheelers off road sells but is also available on Amazon for less with free Prime shipping. Just put the part number in a google search and see the options that pop up. Cheers
