Front Coil Spring Rates Pro, OR, Sport, SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grossomotto, Aug 9, 2019.
  1. Aug 9, 2019 at 1:49 PM
    #41
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    It's not the nose of the truck. It's the electronics, airbags, sheet metal, frame, moon roof, transmission, motor, etc, all the little changes to the entire truck add up to 300 #'s.
    eurowner likes this.
  2. Aug 9, 2019 at 2:10 PM
    #42
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Apples to apples as far as config, ill be weight differences are within 100lbs. Also... all that weight is BEHIND the rear axle so load is shared between front and rear axles.
    Stiffer spring rate of the 3rd gen is for slightly higher ride height and more sporty feel compared to the boat like ride of the 2nd gen.
  3. Aug 9, 2019 at 2:13 PM
    #43
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    All true. We'll sort of anyways.
  4. Aug 9, 2019 at 2:15 PM
    #44
    SpeySquatch
    2016 TRD OR DCSB
    Yep thanks for finding this. Not sure why it’s so hard for people to understand the 3rd gens have a heavier coil for supporting the front weight easier. It’s like the difference of holding a 10# weight at your chest and then with arms extended out
    juandirt and RangerComa[QUOTED] like this.
  5. Aug 9, 2019 at 2:16 PM
    #45
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Numbers don't lie. :cheers:
    SpeySquatch[QUOTED] likes this.
  6. Aug 9, 2019 at 2:55 PM
    #46
    SpeySquatch
    2016 TRD OR DCSB
    Even after speaking with a Toyota tech, he even agreed the 3rd gens are heavier based on the dims and how the weight is distributed thus needing heavier coils
  7. Aug 9, 2019 at 3:42 PM
    #47
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Agree. No way the stock front coil is rated 700lb. I replaced my Offroad front coil with B6112 coils and it was much much better/noticeably firmer. Keep in mind that the coil that came with B6112 are rated 610lb. I replaced that with Eibacj/King 700# and it is totally harsher than the two i replaced. People usually upgrade to 650lb. 700lb is totally a different beast.
  8. Aug 10, 2019 at 11:32 AM
    #48
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I tried this today and I could not get the thing together. I put the left shock up one and left the right on the bottom, but I haven't driven it yet.
    I have a DCLB 2012 with 45k miles. The springs are OME 884x.
    OK so they're 40#/" heavier than the stock ones were 7 years ago . . .
    That's about what I was hoping for.
  9. Aug 10, 2019 at 3:20 PM
    #49
    Grossomotto
    Grossomotto [OP] Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just to recap, we’ve found the OR springs at around 715lbs. The Pro are fox which can be found. Anyone know the Sport and SR spring coil rates?
    shane100700 likes this.
  10. Aug 10, 2019 at 3:44 PM
    #50
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    717#'s. But who's counting.
    Fox pro coil: 12.3x3x650#.
    https://www.tacomaworld.com/threads/coil-spring-rate.591339/#post-19947788
    You literally posted above and below his post. :rofl:
    I'd be willing to bet that all 4x4 springs are the same, but that the shocks are valved differently between them all.
    2x's, well they are significantly lighter so I'm guessing they are going with a lighter spring for those. But not a lot of folks around here really care. :boink:
  11. Aug 10, 2019 at 3:47 PM
    #51
    Grossomotto
    2017 4WDV6LB6MT
    Ok I’ll look at all this, gets a little confusing as I get older
    RangerComa[QUOTED] likes this.
  12. Aug 10, 2019 at 3:47 PM
    #52
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    For everyone else that can't believe the third gen has a 700# + coil, then tell that to @Toytec Lifts because then they must be lying about their test results.
    :facepalm:
  13. Aug 10, 2019 at 3:51 PM
    #53
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I would like to see the spec sheet they alluded to, but never posted.
  14. Aug 10, 2019 at 4:01 PM
    #54
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Well now that you say it. I'd like to see it too.
  15. Aug 10, 2019 at 4:04 PM
    #55
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  16. Aug 10, 2019 at 4:29 PM
    #56
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Thanks guys! It worked! 1/4" spacer wouldn't have done it.
    But this truck is within a smidgen of perfect.
    I'm gonna bow out and go post details in the Gen2 room.
  17. Oct 8, 2019 at 8:41 PM
    #57
    Prowlah
    Prowlah Well-Known Member
    SoCal
    2017 Silver DCSB TRD Sport 4x4
    So is there any confirmation that stock springs are 700+ lbs?
