Front Coilsprings rubbing UCA joint
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttran, Feb 16, 2011.
  1. Feb 16, 2011 at 6:48 PM
    ttran
    ttran [OP] Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    I recently installed my new suspension (bilstein 5100's with eibach coils) and ever since I've been experiencing a rough CLUNK everytime i'd go over a speed bump or something of the sort. I took a look at my spring today and all the paint has been worn off the spring from where it rubs the uca. Any tips on how I can stop this?
  2. Feb 16, 2011 at 7:18 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Yea, lower the settings on the bilsteins... What are they set at? They shouldn't be set at ANYTHING BUT 0.
  3. Feb 16, 2011 at 7:20 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    They're set at 0 with eibach coils
  4. Feb 16, 2011 at 7:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    x2
    If you have the right Eibachs, they say you get 3" out of the springs with the 5100's set at 0 (bottom clip position)
    Any pics of install woukld help greatly just my $.02 ;)
  5. Feb 16, 2011 at 7:23 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Hmmm, I'd re check part no.# maybe.. just throwing it out there..
  6. Feb 16, 2011 at 7:26 PM
    Supra TT
    Eric
    Indiana
    Also, the clunk probably is BJs ... not the coils
  7. Feb 16, 2011 at 7:28 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Just checked the bilsteins, Seem to be the right ones with the clip setting all the way at the bottom. And yes, I'm almost positive it's the ball joint on the control arm that's rubbing the spring
  8. Feb 16, 2011 at 7:29 PM
    Supra TT
    Eric
    Indiana
    He ment check the eibach springs
  9. Feb 16, 2011 at 7:31 PM
    Supra TT
    Eric
    Indiana
    If you truely want that eliminated, get new UCA from total chaos or camburg.
  10. Feb 16, 2011 at 7:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No pics Tim ?? This may be a dumb question but are they (coils) sitting in spring seat correctly ?? (sorry,had to ask)
  11. Feb 16, 2011 at 7:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Was/is there an issue of the Eibachs, or rather the UCA ball joints rubbing on coils ?? I read up a bit on the Eibachs w/5100's & never saw it mentioned... just wondering...:notsure:
  12. Feb 16, 2011 at 7:36 PM
    Supra TT
    Eric
    Indiana
    No idea, but UCA's are still nice to have even if you have issues or not
  13. Feb 16, 2011 at 7:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Oh yeah, absolutely...;)
  14. Feb 16, 2011 at 7:39 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    yes spring is seated correctly. Just went outside to take some pics but I seem to have lost the cable to connect my camera to my laptop haha. I only hear the clunk over bumps and such other than that it rides fine
  15. Feb 16, 2011 at 7:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Are you sure the spring perches aren't upside down?
  16. Feb 16, 2011 at 7:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Before anyone piles on this question, its totally legit to ask, At a glance it would be real easy to put them upside down, cause initially it looks "right"
  17. Feb 16, 2011 at 7:42 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    before i got Camburg uca's, my stock uca's would hit the sides of my 3" OME coils at full droop... not sure if thats the same problem OP is having, but aftermarket uca's solved my problem
  18. Feb 16, 2011 at 7:45 PM
    TexasTacoma37
    Thanks Doug.
    The spring perch should look like a bell when installed correctly. It's very easy to install it upside down.
  19. Feb 16, 2011 at 7:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I think the UCA's & LCA's on 1st gens are alot diff. config than 2nd gen. but at full droop guess it may not matter, but there again you have the EMU's & he has the Eibachs, if it makes any difference anyway...not sure...:)
  20. Feb 16, 2011 at 7:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Exactly, the first set of coil overs I did I almost did this very easy to make mistake...:eek::D
