Front Creaking sound solved
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Aug 3, 2009.
  1. Aug 3, 2009 at 9:16 PM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    2005 Taco developed a creaking sound in the front area. Progressively got worst till I could not stand to have Stealership screw with it anymore...Thought it was the breaks, wheels, front end...
    It was the aluminum front bumper. dropped the alum bumper from the frame(6 nuts 14mm) worked it out from the plastic bumper cover without removing the cover...5 tricky, pry it off the frame bolts, twist it upward and slide it to one end as much as possible then pull it down flexing the plastic bumper cover a bit. The 2 attached brackets (6-14mm nuts)...These 6 nuts were loose or slightly loose. used a 1/2 drive to get more leverage and put it to them....No more annoying squeek/creak crap...
  2. Aug 4, 2009 at 7:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Nice find!
  3. Sep 13, 2009 at 9:03 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Excellent detective work! How many miles did you have on your '05 when the problem started?
    I am searching for the cause of the creaking sound coming from the drivers side door sill area on my 09'. I think mine is a week join in the sheet metal. It drives me nuts.
  4. Sep 13, 2009 at 10:14 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Not a very smart idea to remove that impact bar...
  5. Sep 13, 2009 at 10:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    He removed it to tigten the nuts on the mounting bracket, then reinstalled it. :)
  6. Sep 13, 2009 at 10:22 PM
    rossk35
    hawaii
    oh haha my bad. The way he typed it up made it a little confusing to read.
  7. Sep 13, 2009 at 10:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought the same too. ;)
    Alexely999 likes this.
  8. Sep 14, 2009 at 6:06 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    LOL...No reinstalled it after tightening the 6 bracket bolts........05 had about 30k on it....
    The noise is back..................the only thing to do now I think is to have someone weld it up on each bracket and then reinstall back to the frame...........I have 53,000 on it now.
  9. Sep 14, 2009 at 8:19 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks for letting us know. :)
  10. Jun 19, 2013 at 10:19 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    So anyone else have a creaky front end and come up with a fix?
  11. Jun 19, 2013 at 9:05 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Hey, mine still creaking... Mine is the alumimun front bumper. The two parts that extend forward from the long L-R part are bolted together, I tightened mine and they stopped for while...
    I am going to pull mine and have someone heli arc the alum(weld it). I am sick of it. I love my truck, but this and the damn front wheel shack SUCKS.
    Mine 2005 4door. Pre.
    You can pull that alum bumper out with out taking the plasitc bumber off. Can't remmber, but a little tricky.
  12. Aug 3, 2013 at 5:21 AM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    mine was doing this i tightened them down and it got rid of it for little while. But it came back, i was thinking of putting rubber washers/bike tire tubing between the bolts. Might as well get a demello bumper to fix this problem :D.
  13. Aug 3, 2013 at 5:31 AM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    How about using Loctite on the bolts?
  14. Aug 31, 2014 at 7:21 PM
    kendj
    kendj New Member
    Ken
    Calgary
    05 PreRunner
    The creaking sound when the truck frame flexes comes from the bolts that connect the aluminum support to the aluminum beam. Bolts are tack welded and can't be accessed. When the weld breaks loose they make noise. You can either buy new alum supports from Toyota or weld up your own out of steel.
    Crom likes this.
  15. Aug 31, 2014 at 7:23 PM
    kendj
    kendj New Member
    Ken
    Calgary
    05 PreRunner
    I built two supports out of steel this weekend. Everything is tight and quiet forever...
    Bodyguard89 and Crom like this.
  16. Aug 31, 2014 at 7:25 PM
    kendj
    kendj New Member
    Ken
    Calgary
    05 PreRunner
    Support is steel and 3 attachment bolts are 3/8" by 1.5" Grade 8. Welded in from behind.
    Crom and Gregman like this.
  17. Apr 25, 2016 at 11:15 AM
    Gregman
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Great job kendj !
    Crom likes this.
  18. Jun 11, 2017 at 12:28 PM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    What! All my searching! And this is the problem!
    Well. Time to get my grease pants on and go tighten some bolts!
  19. Sep 17, 2018 at 5:09 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I know this is an old thread, however I just loosened the six 14mm nuts and the creaking is gone! Hallelujah!
    I checked the nuts over a year ago when I replaced my headlights and had the bumper cover off and they were super tight so I thought they couldn't be the cause.
    Anyways when I get more time I'm going to put nylon washers between the aluminum and steel
    syswalla likes this.
  20. Feb 9, 2019 at 11:55 AM
    jaymay82
    jaymay82 Well-Known Member
    '13 MGM TRD Sport DCSB
    So glad I found this thread. Creaking noise has been driving me nuts. Really thought it was a suspension issue. Never would have suspected a body issue. Tightened the nuts and it stopped. Thanks so much.
