Front Crossmember Replacement Possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06 tacoma owner, May 19, 2015.
  1. May 19, 2015 at 11:09 PM
    06 tacoma owner
    06 tacoma owner [OP] Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    I have a drop bracket lift on my truck and i'm wanting to get rid of it and make it stock and put another lift kit with coilovers and the crossmember has been cut. Is it possible to buy another crossmember and weld the part of it back in that has been cut off? The one I'm referring to is #2 in the picture.
  2. May 20, 2015 at 10:42 AM
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
  3. May 20, 2015 at 10:47 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    What drop bracket do you have? Assuming you can order the crossmember and have the old cut out and new welding in properly. I dont see why not?
  4. May 20, 2015 at 11:23 AM
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    I have a Tuff Country 4" drop bracket. I've looked at different part websites and none of them sell the part individually.
  5. May 20, 2015 at 11:34 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    You could always make one
  6. May 20, 2015 at 11:45 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Yeah I kinda had that feeling you cant just get the crossmember. Is the entire crossmember cut out or just partial?
  7. May 20, 2015 at 11:46 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
  8. May 20, 2015 at 11:48 AM
    Manwithoutaplan
    ID
    Are you sure it is the # 2 ???
  9. May 20, 2015 at 12:14 PM
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Pretty much the whole thing except the ends that are connected to the frame.
  10. May 20, 2015 at 12:18 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Ouch, yeah maybe even check a junk yard if you want it to look factory. Or like others have done and ruggedT have done. Just have a piece of stock welded back in along with a mount for the rear of the diff
  11. May 20, 2015 at 12:18 PM
    06 tacoma owner
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    I went and looked underneath the truck and the one that is actually cut is #3. I know what I could do to fix it. Just what ruggedT did with his just weld a couple flat plates on the sides and weld some square tubing in between.
