Front CV
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkyardyote, Apr 12, 2023.
  1. Apr 12, 2023 at 6:47 PM
    junkyardyote
    junkyardyote [OP] Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I replaced my passenger CV and when I was finished it felt like the CV was binding. I pulled the steering knucle off again to see where the bind is. It seems to only do it when the shaft is in the hub. One more thing is it seemed to be harder to get it in and out of the hub splines than before. I am a little concerned that I may have over torqued the axle nut. I ran it on with a wrench that only went to 150,then hit it with an impact for just a second. I did see the nut move tighter in that brief time.Also did the lower A arms at the same time. Please advise. Thanks
  2. Apr 12, 2023 at 8:34 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Does it make any weird noises when you drive?
    What makes you suspect binding?
    hoffengineering and gearcruncher like this.
  3. Apr 12, 2023 at 11:20 PM
    junkyardyote
    When I turn the wheel(hub) by hand it does not feel smooth. Its clunky.
  4. Apr 13, 2023 at 1:56 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    It's normal if you turn it by hand and there's a bind with the suspension unloaded at a high cv axle angle(especially passenger side). Put a jack under the control arm and load the suspension then turn by hand. It should turn smoothly. Where did you get the cv axle?
    Things to recheck:
    1. Tug on the axle going into the diff to make sure it is fully seated and locked(should not come out by hand)
    2. Make sure there is nothing between the outer cv flange and the hub bearing (dirt, debris, etc)
    3. Check the splines to make sure there's no damage. I've seen remand/new axles that had damaged splines and wouldn't slide in all the way.
    4. Torque/retorque all fasteners
    CTSpruceMica likes this.
  5. Apr 13, 2023 at 5:50 AM
    junkyardyote
    I will do this this evening after work and report back,thank you.It is a new OEM axle from a dealership.
    MA_TACO[QUOTED] likes this.
  6. Apr 13, 2023 at 7:02 AM
    Naveronski
    Fort Worth
    Great point here.
  7. Apr 13, 2023 at 7:10 AM
    junkyardyote
    OK,so I looked at it this AM. Put the suspension under full load. No binding. I didnt realize that the pass side had so much more of an angle at full droop. I think it solved. Now if I can just get the tie rod nut to thread on. I guess Ill chase the threads and if that doesnt work Ill replace the end. Suggestions welcome on that too:frusty:
    Naveronski likes this.
  8. Apr 13, 2023 at 7:43 AM
    MA_TACO
    Wesley Chapel, FL
    Use the bar in this kit to restore the threads https://www.amazon.com/Angchun-Metric-Universal-Restorer-Rethreading/dp/B0BNX7S4LD?crid=WDUTR08DLQYC&keywords=thread+restorer+tool&qid=1681396841&sprefix=thread+restorer+tool%2Caps%2C157&sr=8-1-spons&th=1
    EDIT: just noticed you said the nut may be cross threaded. Not sure what size nut it is but the correct size might be in this kit. If not there are larger kits available on Amazon.
  9. Apr 13, 2023 at 7:48 AM
    junkyardyote
    I will order that tool,however I just put a wood block under the tie rod and whacked it to engage the taper and it threaded on with no concern.I want to thank you for the responses. My only option was to get this sorted at home and its nice to have the support.:thumbsup:Edit: The best thing I did was walk away for a bit and come back to it,I was really frusterated last night.
    Naveronski and MA_TACO[QUOTED] like this.
