Front dif mounting cushion - looking for a "how to"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 9, 2021.
  1. Sep 9, 2021 at 2:49 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Can't find any instructions on replacing this. Can I "simply" jack up the differential until the part clears the crossmember?
  2. Sep 9, 2021 at 3:15 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The FSM removal section is not that helpful in regards to this..
    One thing I did discover after a quick search, is that the rear mount is held in with a 10 or 12mm allen bolt, so make sure you have those on hand before attempting.
    Maybe try searching through some of the 4wd conversion threads, paying attention to how to install the new diff, and see what issues they have had.
    Edit: I'm also not sure how mission-critical that bushing is in the scheme of things...
    Kristi with a K[OP] likes this.
  3. Sep 9, 2021 at 3:29 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    It is the last step on removing the diff, so I think you'll need to follow all of the steps to lower it enough to replace it.
  4. Sep 9, 2021 at 3:48 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    mmm guys who pull the front diffs for 4wd conversions all seem to just remove the cv axles, and leave the stub shaft (TUBE in the FSM) in place. So being that she just needs to clear the rear mount, I'm not sure she'd have to remove the tube.
    I'd wait for someone to chime in who has had to either install or remove the front diff to advise.
  5. Sep 9, 2021 at 3:57 PM
    Kristi with a K
    Western MA
    Would I be looking to lower the differential? Wouldn't I actually need to raise it enough the clear frame crossmember it inserts into.
  6. Sep 9, 2021 at 4:09 PM
    Kristi with a K
    Western MA
    I'm thinkin' that maybe it's this -
    Plus probably best to disconnect the driveshaft at the front dif.
  7. Sep 9, 2021 at 4:10 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I just installed my front differential.
    There isn't a whole lot of clearance above it but it might be possible to rotate the rear upwards enough to get to the two bolts that hold the mount to the diff. I would loosen the front diff bolts but not take them out since the whole assembly will be hanging from the front axles.
    It only needs to move up enough to loosen those two bolts and rotate out of the way.
    Bivouac and Kristi with a K[OP] like this.
  8. Sep 9, 2021 at 4:18 PM
    Kristi with a K
    Western MA
    I thought I had done everything from front to back. The front diff bushings were the final parts to complete the mounting & suspension rehab. When I saw this mount a couple of days ago I was dismayed? surprised? bummed? & within a few minutes, mission driven to take on the final, final part to the mounting & suspension rehab....
  9. Sep 9, 2021 at 4:32 PM
    Kristi with a K
    Western MA
    So I'd be rotating the diff out of the way as opposed to raising it enough to clear the mount stud. Should I disconnect the drive shaft?
  10. Sep 9, 2021 at 4:41 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It depends if you have enough movement at the u joint driveshaft flange to get enough clearance .
    I would need to be under the truck to be sure.
  11. Sep 9, 2021 at 5:35 PM
    Kristi with a K
    Western MA
    Sounds like it'd be smarter to unbolt it since I wouldn't be a good judge of whether it had enough movement.
    Bivouac[QUOTED] likes this.
  12. Sep 9, 2021 at 5:36 PM
    Kristi with a K
    Western MA
    Thank you all.... I just ordered the part yesterday, so it'll be at least a few days if anyone thinks of anything else....
  13. Sep 17, 2021 at 9:53 AM
    Kristi with a K
    Western MA
    The mount finally came in. Just double checking the suggestions for “how to”.
    1. Mount ready to take out
    2. Loosen all front mount bracket bolts
    3. Removed front drive shaft from
    dif
    Soooo.... next would be -
    4. Raise the dif a pinch (looks like there’s about 1in)
    5. Rotate mount to remove left bolt
    6. If need be (looks like need will be), with dif on floor jack, slowly ease it left until I have cleared the bottom mount stud.
    Questions -
    1. the axles should be ok as is? & as is is, sway bar, steering rack & coilovers are removed.
    2. Anything in particular I should look for that would qualify as an abort or reassessment?
  14. Sep 17, 2021 at 10:21 AM
    Kristi with a K
    Western MA
    Ok. Ok. Re-read. The idea is I may have enough room to clear the stud. Not to necessarily move the whole dif. I mean that of course would be the ideal. Is it possible to move the dif a pinch to the left to get a little more clearance if need be?
  15. Sep 17, 2021 at 11:05 AM
    Kristi with a K
    Western MA
    Done! It cleared just fine, no probs! Thank you all :)
    Area51Runner, beez and Bivouac like this.
  16. Sep 17, 2021 at 3:29 PM
    Bivouac
    Glad that is complete !!
    What is next on your list?
  17. Sep 17, 2021 at 4:20 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    @Kristi with a K did you happen to take any pics/video? Would be a great write-up to include in the sticky threads
  18. Sep 17, 2021 at 9:08 PM
    Kristi with a K
    Western MA
    New steering rack is part way in. Then reassemble the steering column/wheel. Install new coilovers. Then take apart the steering wheel to center it. Compressor or clutch needs to happen. Still have to figure out how to figure out which way to go with that. Oh, & finish painting. Bed is done.
  19. Sep 17, 2021 at 9:13 PM
    Kristi with a K
    Western MA
    I did not. I don't think of what I do as being anything write up worthy. I could attempt something. Send it to you to proofread because I have the gift of unintentionally confusing people. When someone does it down the road maybe they could add better pics?
  20. Sep 17, 2021 at 10:33 PM
    Kristi with a K
    Western MA
    Install fender, bumper bracket.... I think this is becoming a Kristi reminder list. You asked what's next. After reassembly, centering the wheel, alignment & if all went well, a roadtrip with my camera. Maybe catch some foliage this year....
