front diff bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silver_Taco, Mar 3, 2010.
  1. Mar 5, 2010 at 6:30 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    The seals were replaced without taking the diff apart. They only had to replace a small amount of fluid.
  2. Mar 5, 2010 at 6:35 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Any way to test a wheel bearing aside from funny noises?
  3. Mar 5, 2010 at 7:51 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    So you can replace the seals without taking the CV out? :confused:
  4. Mar 5, 2010 at 7:57 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I was always told to jack up the front so the tires are off the ground, grab tire top and bottom then push/pull in/out with force. if there is play the wheel bearings are bad. Mine seem to be tight but I still have a funky noise:notsure:
    not possible
  5. Mar 5, 2010 at 7:57 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Thats a good question X2
  6. Mar 5, 2010 at 8:00 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Thats what I thought, I think I misread it. Thanks everyone
  7. Mar 21, 2010 at 7:30 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Well, you're certainly not alone. Never had the rear leaf TSB done, and really wanted to add the extra leaf. Installed the Wheeler's 1.5" AAL and 5100's all around last week (set the fronts to 1.75). I got the "vibe of death" that so many get. Haven't made it through the 35 page thread on TN yet. But it is funny how it won't go away if you coast, but clicking it in 4WD (even when it never locks up in 4WD) the vibe goes away. Can use the 4WD switch like a light switch...turn the vibe on and off (doesn't matter if it locks in 4WD or not). Why would that be? Is it the front diff that locks first, then the transfer case...or the other way around? The one that locks first must be the culprit since the vibe goes away before the latter solenoid locks it up.
    EDIT: cj99si had this problem years ago. Adding the lift points out that the front diff bearings are bad and need to be replaced. Checked play in the front shafts and can move both almost 1/4 of an inch! Looks like out front diff bearings are probably all going to fail before 160K miles (I'm at 88K now and have that much play in them). Either replacing the front diff or replacing the bearings will eliminate the vibe.
  8. Mar 22, 2010 at 4:44 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    There doesn't have to be play in the bearing for it to be gone. Swerve left to right like the above poster said, if the noise goes away when steering in one direction or the other, chances are its a wheel bearing. Also jack up the truck and spin the wheel by hand. You should have no problem hearing the shot bearing as the wheel rotates.
  9. Mar 22, 2010 at 7:47 AM
    Silver_Taco
    Silver_Taco [OP] Senior Member
    Frederick, MD
    We're talking about 2 completely different issues. Wheel bearing noise doesn't go away in 4WD.
    If you have a failing wheel bearing, it will happen all the time when turning one way or the other.
    If you have a problem with the carrier bearing in the front diff, it will happen mostly when cold and usually go away after driving at highway speeds for a bit - also, goes away as soon as 4wd is engaged.
  10. Mar 22, 2010 at 9:47 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    This is exactly the problem I am having!! So the output bearings from the front diff are the problem? I had one shop tell me its transfer case and my dealer wont admit there is a problem.
    Is this a possible DIY job?
  11. Mar 22, 2010 at 10:07 AM
    Silver_Taco
    Frederick, MD
    I've never done it so dont know. With the right tools, anything's a DIY. :D
    For now, I'm just gonna let it roll. If we had disco's on the front half shafts, would never hear the noise and since i don't hear it in 4wd, not gonna get too excited about it. Might tear into it later in the summer but not in a hurry.
  12. Mar 22, 2010 at 11:28 AM
    Silver_Taco
    Frederick, MD
  13. Mar 22, 2010 at 11:31 AM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    Had this same issue twice already, I guess im too harsh on my Taco
  14. Mar 22, 2010 at 12:00 PM
    05Moose
    Jim
    I looked at the instructions for changing the bearing. Looks complicated enough that I'd be afraid to tackle it myself. The removal/install instructions are attached.
  15. Mar 22, 2010 at 12:33 PM
    #35
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  16. Mar 22, 2010 at 4:15 PM
    #36
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Well my front end rattle seems to be only with the drivetrain under load (ie idling up my slightly inclined driveway) or with half throttle once moving:confused:
  17. Mar 30, 2010 at 4:57 PM
    #37
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Man I just got this truck replaced the drivers wheel bearing and cv axle and still have a bad vibe as soon as I drive it. I think my diff bearings are shot.
  18. Mar 31, 2010 at 9:09 AM
    #38
    05Moose
    Jim
    But does it go away when you switch it to 4WD...will go away before the transfer case engages. Just flip the switch. Doesn't matter if the 4WD light in the dash is flashing because it will go away even with it flashing.
  19. Apr 1, 2010 at 1:11 AM
    #39
    Trapper6speed
    Stock
    It's has a little less noise, but when I reach under there that bearing has way to much play. I just redid the wheel bearing that was bad the outer race on it was toast. I have some bearings on the way if not I have a replacement diff in line.
  20. Apr 2, 2010 at 9:31 AM
    #40
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Well I took my truck to the dealership to get this diagnosed. I took a ride with the tech and he immediately noticed the noise, I showed him how it went away in 4WD and mentioned before it fully locked in it went away. I also mentioned that the CV's have play in them and he agreed that it felt like it could be the front diff.
    So I agreed to pay $65 for diagnosis and I hopped in my corolla loaner and expected to hear back in a few hours with a diagnosis.... 8pm rolls around and nothing. So I call the next day, they say they're still looking and I need to pay another $120 for diagnosis ($185 total) I begrudgingly agree cuz I want this taken care of.
    So I finally get a call late Wednesday (after bringing it in first thing Monday) that they can't figure it out. They listened to different things with some "stethescope" but still can't figure it out. The kicker is they still expected me to pay $185 which I got knocked down to $0 after having a chat with the service manager so I can't fault anyone for that.
    But I just want this taken care of and after reading this thread and the ones over on TN i'm 95% sure it's the front diff bearings. I'm almost to the point of screwing my extended warranty and rebuilding the diff with some help from one of my friends who is a Ford mechanic
