Front Diff Drain Bolt Upgrade?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh-L, Sep 11, 2023.
  1. Sep 11, 2023 at 12:51 PM
    Josh-L
    Josh-L [OP] Well-Known Member
    2021 Silver SR DCSB V6 4x4
    Going to do my first service on my front/rear diffs and t/c next weekend. I've watched several YouTube videos and read several posts that the drain bolt on the front diff likes to get stuck, and you have to destroy it basically to get it off. I swear I had saved where there was an upgraded bolt to avoid this, but I can't find it now. I'd like to have one on hand when I do this service just in case. Does anyone know what I'm talking about or know the part number for the factory replacement so I can have a spare just in case?
  2. Sep 11, 2023 at 12:55 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Here's what I used.
    Toyoya 90341-24016 PLUG, STRAIGHT SCREW https://www.amazon.com/dp/B01F7MAXX4
    RustyGreen likes this.
  3. Sep 11, 2023 at 12:57 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Also, be sure to remove the fill port, before you remove the drain. Don't want to drain it, only to find out you can't fill it.
    drizzoh and RustyGreen like this.
  4. Sep 11, 2023 at 1:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    2-3 year old truck won't have a problem with rust at this location. Just make sure there's no debris in the hex cavity and your hex bit is fully seated. Tap it in with a hammer if necessary.
    On install, coat the plug threads in some gear oil and you won't have a problem with subsequent removals.
    Chenmwu, NoOne, jmneill and 4 others like this.
  5. Sep 11, 2023 at 1:04 PM
    Josh-L
  6. Sep 11, 2023 at 1:07 PM
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    folks suggest Lexus part will fit.
    easy search on the forum.
    I loosened my 2022 drain plug a few turns to check if it was seized.
    Required a breaker bar and tapping the drain bolt to ensure it loosened.
  7. Sep 11, 2023 at 1:57 PM
    17tacotrdor
    17tacotrdor Well-Known Member
    SOCAL
    2019 TACO
    Pb blaster on it and wait 10 minutes
    Chukar Chaser, Scotty61 and Chew like this.
  8. Sep 11, 2023 at 7:07 PM
    Trail_Limo
    Trail_Limo Well-Known Member
    G
    Land of fruits and nuts
    Turd Gen OR Limo
    I just changed the oil on my diffs 2 days ago.- the front diff hex bolts were not bad at all. I hit it with PB plaster, then after 15 min I made sure the 10mm hex was fully inserted and both came out without any drama.
    You just have to handle that hex bolt like a woman; insert fully, be gentle yet firm, and not be afraid to give it a few smacks if it requires.
    ricco333, dryheat, 44-16 Taco and 2 others like this.
  9. Sep 11, 2023 at 10:34 PM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    I used heat, leat it soak 15 minutes, hit it with the impact and came right off.
    I did have new oem as backup.
    Brucey likes this.
  10. Sep 12, 2023 at 3:48 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    mine came out easy and i did this 'upgrade'. it is overrated imo. there is nothing wrong with or need to improve the factory plugs. as mentioned above, make sure they are clean and free of dirt and grime, and use the proper tool.
  11. Sep 12, 2023 at 3:58 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Its not going to rust.. it will strip out
    BoomerGVNG likes this.
  12. Sep 12, 2023 at 5:40 AM
    Devolve
    Devolve Active Member
    Ontario, Canada
    2019 Cement DCLB
    I think this is a bit overblown. I overanalyzed it as well and bought the "upgrade" plug before doing it. I had a torch, chisel and hammer etc on standby and it loosened up with barely any effort. I replaced the plug anyway but I definitely didn't need to.
  13. Sep 12, 2023 at 5:49 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The Allen plugs are not that bad. The only reason I did the swap to the hex ones is because I don’t commonly use the Allen tool and I end up losing it and not have it when I need to do swaps. Easier to just have it as hex because I know I’ll have the socket handy anytime.
    Successful Allen plug life is having the right size tool and a quality tool. As long as the hole is not filled with dirt, it shouldn’t be a problem.
  14. Sep 12, 2023 at 5:49 AM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    Just did a diff service on my 2021. The plugs came out without a problem. I did replace both the fill and drain with hex, I got them at the Lexus dealer.
    9034118060 (fill)
    9034124016 (drain)
  15. Sep 12, 2023 at 9:50 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    If you want a little extra protection against it seizing up, coat the plug with your favorite corrosion inhibitor afterwards to prevent anything from migrating into the threads. I used RP-342 when the truck was new and at 15K miles, the plug came out with zero fuss. No data to prove it was better or worse without it, but I had no issues and recoated it against afterwards.
    Volt likes this.
  16. Sep 12, 2023 at 10:27 AM
    Chukar Chaser
    Chukar Chaser Well-Known Member
    Pete
    So Cal
    2019 TRD OR 4X4 DCLB
    Just did my first differential and transfer case fluid change on my 2019 TRD ORLB. I live near the ocean, so just to be sure, I sprayed some WD40 on the plugs a couple times, and then tapped a little with a wrench. As others have noted, as long as you insert the hex fully and use a breaker bar carefully and keep it level, it's not difficult to loosen the plugs.
  17. Mar 28, 2024 at 10:25 AM
    JackedIroh
    JackedIroh Member
    Jake
    2021 Cement SR5 Trail Edition
    Is this for both the front and rear diff?
  18. Mar 28, 2024 at 1:17 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Front. The rear are both hex head already.
    Barsoom and JackedIroh[QUOTED] like this.
  19. Mar 29, 2024 at 4:17 AM
    LFOD
    2021 SR5 DCSB
    front diff only, drain and fill
    rear diff already has hex drain/fill plugs
  20. Jun 30, 2024 at 1:03 PM
    AlaskanML
    AlaskanML Member
    Morgan
    fairbanks alaska
    2017 Tacoma TRD
    does the lexus style use the same gasket or do you need a different gasket...for my sons 2016
