Front diff drain bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soulsurvives, Sep 18, 2022.
  1. Sep 18, 2022 at 6:51 PM
    Soulsurvives
    Soulsurvives [OP] Well-Known Member
    Bill
    2009 Tacoma
    So I did the fluid change in my front and rear diff along with my transfer case this weekend. My issue was with front diff drain bolt. I was not able to get it out. I ended up siphoning out the old fluid, which was nasty as hell from the fill hole. Any ideas on how to get that pesky drain bolt out? Thanks.
  2. Sep 18, 2022 at 6:56 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Spray some PB Blaster on it and let it sit overnight.
  3. Sep 18, 2022 at 7:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Before it gets too rounded, spray it.
    Then place a small ball peen against the plug, and hit the hammer with another slightly larger hammer. This will shock the plug.
    Then hammer in a proper 10mm allen key socket, and remove.
    If all else fails, you have to indent with a chisel, and "walk" the chisel point out.
  4. Sep 18, 2022 at 7:56 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Might put a torch to it too and heat it up a bit.
    10thMTNgrunt and Key-Rei like this.
  5. Sep 18, 2022 at 8:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you got most of the old fluid out (~1.5L), the easiest thing is to leave it as-is.
    Because the drain plug hasn't been removed in 13 years, removal methods will likely be destructive. If you really want to remove it, have a replacement drain plug and crush washer on hand.
    JAGCanada, reallifedog and Squirt like this.
  6. Sep 18, 2022 at 8:24 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I recently had this issue too. Even my Milwaukee impact couldn't budge it.
    Had to jack up the truck and then use a 18in cheater bar and was able to loosen the plug. I reduced the torque spec by 10% when I reinstalled it.
  7. Sep 18, 2022 at 8:38 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    I pretty much had the same problem. I almost totally rounded the plug due to the rust not letting it go in all the way. After I realized it's not going to be reusable I went and got a new plug and washer. I then hammered the allen socket in, said a prayer, and used a breaker bar to loosen it. It worked out perfectly! It seemed that the previous owner had a hard time trying to get it off and never changed it again as the color of the fluid was absolutely jet black!
  8. Sep 18, 2022 at 9:56 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    If you do get it out, i recommend changing to Lexus part # 90341-24016. I swapped this over when i changed my fluid relatively cheap maybe $10. Double check the part # but this is a 14mm nut rather than a 10mm hex that always strips out.
    WOODY2, reallifedog and DavesTaco68 like this.
  9. Sep 18, 2022 at 10:02 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    There is a company that makes an extraction tool specifically for that. It’s a little expensive around 30 dollars I think I don’t remember exactly but it worked great on mine. Had the sam issue.
  10. Sep 18, 2022 at 10:45 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    All else fails you weld a nut on there and the heat will help loosen, then zip off with standard 1/2” impact socket.
    reallifedog and Blockhead like this.
  11. Sep 19, 2022 at 3:43 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    ^^^This^^^
  12. Sep 19, 2022 at 3:52 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    What everyone else said! :D
    I had the same problem when I changed my fluid right after buying my truck and ended up using the chisel method. It was slow going but it worked. The best part? Finding out that the PO had it changed just a few months prior... :frusty:
  13. Sep 19, 2022 at 5:35 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    reallifedog likes this.
  14. Sep 19, 2022 at 1:19 PM
    balls47
    balls47 Well-Known Member
    Western Colorado
    99 TRD OR, 2014 DCLB TRD Sport
    Once you get it out replace it with this plug which is a better setup. Toyota/Lexus
    90341-24016.
    2015WhiteOR likes this.
  15. Sep 19, 2022 at 1:20 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
