Front diff drain plug leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigmooze, Feb 20, 2012.
  1. Feb 20, 2012 at 4:47 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I had my diff fluids changed at the dealership about 4000 km ago. Under the truck yesterday, I noticed some oil gathering on the bottom of the front diff and at the drain plug.
    Cleaned the area well with degreaser and wiped everything off. Today I see a small amount of oil leaking from out of the drain plug. Not major, but it's leaking. It shouldn't leak.
    I intend to take the truck into the dealership for repair under extended warranty, but would like to know whether over-torquing the drain plug and/or not replacing the copper crush washer would cause this. Chances are, they didn't replaced the crush washer.
  2. Feb 20, 2012 at 6:00 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Never, ever, evar let stealership monkeys wrench on your ride.
  3. Feb 20, 2012 at 6:30 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Lol^^^^^^
    Not a single person at a dealership knows how to work on a car. They should all close, and everybody including the hybrid owners should repair their own vehicles.
    OP, there is a small metal gasket under the plug that might be damaged, or installed over the old one. Take it back right away, it should be fixed free of charge. Over torqueing should not cause it to leak unless they completley stripped it out.
  4. Feb 20, 2012 at 6:32 PM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    This is why I do my own maintenance. Take your truck back and get that leak fixed for free or take your business elsewhere.
  5. Feb 20, 2012 at 6:36 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i wouldnt bash all dealerships, mistakes do happen and as long as its not completely dumb and theyre willing to make it right i dont see an issue
    i know most of the techs at my dealership and would trust them with about anything on my truck
  6. Feb 20, 2012 at 6:49 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Check to see if it's loose first?
  7. Feb 20, 2012 at 7:06 PM
    badger
    badger Well-Known Member
    07 SR5
    Technically the aluminum washer is supposed to be replaced at every oil change. If a dealer does the work, they should do that. I don't replace mine unless there is an issue, and there rarely is. I never let a dealer do any routine work on my truck. The reason is that the routine work does not go to skilled techs. It goes to minimum wage guys who aften are hacks. Oil changes and plugs are two areas where I have seen so many screwed up jobs! Learn to do the work if you care at all about your truck. Most mechanics today are working under that damn flat rate. If they strip a bolt or otherwise have trouble they have to eat it. I've always done my own work and I can tell you, shit happens to the best of us. There are lots of good mechanics, but most are not working under good considions. If I get to talk to them, I always tell them to do the work right and I'll cover any problems with them under the table. Mostly though, I do everything myself.
  8. Feb 20, 2012 at 7:10 PM
    Tacoma Mike
    Southern Maine
    Washer might have dropped off the plug during the procedure.
  9. Feb 20, 2012 at 7:25 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Especially in flat rate shops, routine maintinence goes to the most experienced guys/ most seniority. Its called "gravy" and is the easiest work with the most time attatched so more money is to be made. But that is irrelevant to op's post, i just wanted to make a point.
  10. Feb 21, 2012 at 2:41 AM
    bigmooze
    Richard
    Belle River, ON
    Yessir, forgot to write that in original post. Drain plug is tight. Threw a torque wrench on it and it's beyond spec (48 ft-lb).
  11. Feb 21, 2012 at 2:43 AM
    bigmooze
    Richard
    Belle River, ON
    That's true, too. I'll take it in this week and hopefully report back a successful repair.
  12. Feb 21, 2012 at 5:17 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    the washer, i think it is copper. mine were.
    the best thing about dealership work, they typically make it right. take it back.
    when i did mine, the parts person told me they dont need to be changed every time. whatever...the part is cheap. why wouldnt you change it. i wonder if they give you a new seal at the oil change?
