Front Diff. drain plug stuck......
Discussion in '1st Gen. Tacomas (1995-2004)' started by ETaco23, Feb 28, 2010.
  1. Feb 28, 2010 at 4:54 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I was trying to change my front diff. fluid today, but for the life of me couldnt get the drain plug to break free. I tryed everything(except an air gun). I was like :eek: trying so hard! Any idea's? It isnt backwards threads right?
    Thanks
  2. Feb 28, 2010 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nope...righty tighty...lefty loosy. sometimes, they are tight as hell...and being a hex head....more of a pita. may need to get a socket type hex head and use a breaker bar.
  3. Feb 28, 2010 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The front is a Hex, and the rear diff uses the 24 mm plugs.
  4. Feb 28, 2010 at 4:59 PM
    ETaco23
    Evan
    PNW
    no there both 10mm hex. From what it looks and feels like. And Will, I was using the socket type, and a breaker bar, and it still didnt budge!
  5. Feb 28, 2010 at 5:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn. may have to try using an impact gun on a low torque setting.
  6. Feb 28, 2010 at 5:03 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    try a little heat try it after you go for a ride or use a propane torch i had the same problem
  7. Feb 28, 2010 at 5:07 PM
    ETaco23
    Evan
    PNW
    It was warm and I might have to try some heat, or just get a bit for my Impact gun and just do a low setting like Will suggested.
    Well maybe I will do it next weekend, along with my new brakes. (Slotted Rotors and Hawk LTS pads, and wheelers Brake Lines front and rear):D
  8. Feb 28, 2010 at 5:08 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    yah i know what ur goin through there, changed my fluid a few weeks ago and it did the same thing to me. all i ended up doin to get it off was gave the head of the drain plug a couple good whacks with a hammer and it did something freeing it up somehow. it sounds a little fucky i know but thats what happened
  9. Feb 28, 2010 at 5:12 PM
    ETaco23
    Evan
    PNW
    huh... Well maybe I should give that a shot first. Give it a little taparoo with a mallet or something.
  10. Feb 28, 2010 at 5:15 PM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Make sure you loosen the fill bolt first so you can guarantee that you can refill the diff after you remove the drain bolt. A little Liquid Wrench or PB Blaster might help too.
    If your 10mm hex socket is long enough, put a 10mm box end wrench on the hex and put the hex/wrench combo into the drain bolt. Tap the end of the wrench with a hammer. Its a ghetto impact tool but a hammer and wrench often works better than a breaker bar.
  11. Feb 28, 2010 at 5:19 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    breaker bar/cheater pipe?
  12. Feb 28, 2010 at 5:27 PM
    ETaco23
    Evan
    PNW
    Ive used a breaker bar and a hammer, but still nothing. I think I might try some PB on it next time, maybe then it will break loose. Hopefully!
  13. Mar 1, 2010 at 10:05 AM
    2003 TRD Man
    2003 TRD Man Well-Known Member
    Edison N.J.
    03 TRD automatic
    If all things fail--- take to dealer and have them break-it free,they may be kind and charge you 0. Good Luck
  14. Mar 1, 2010 at 10:36 AM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    put the hex socket on a impact driver, give it couple of good smacks then try the breaker bar again. try this a few times if it doesnt work the first time. the impact gun may work but should really be last resort(on drain plugs). the impact driver can free things in the same way without the chance of rounding out the hex, leaving you fubared. oh and yes if all else fails let the dealer break it.
  15. Mar 1, 2010 at 10:38 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    X2
  16. Mar 1, 2010 at 10:42 AM
    madcatter
    madcatter Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    every bolt has a torque value,sounds like yours is grossly over torqued and probably ready to break from to tight.
    i would replace it with a new one
    if it was serviced by someone like a jiffylube/midas then i would address them.
  17. Mar 1, 2010 at 11:17 AM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    the fill plug should always be removed first, to insure proper draining.
  18. Mar 1, 2010 at 11:57 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    not exactly. the reason you remove the fill plug first is to make sure you're able to refill the diff. ....you'd be screwed if you removed the drain plug first and then couldn't get the fill plug out.
  19. Mar 1, 2010 at 12:20 PM
    pdxwhiteout
    coty
    pdx
    monster tacoma
    yeah that kinda goes without saying. but still air flow through the fill hole allows for easy draining. making it a faster and more effective service. thats what i was saying. any tech will always remove the fill plug first..
  20. Mar 1, 2010 at 4:25 PM
    ETaco23
    Evan
    PNW
    I got the fill Plug off no problem. And I will be trying again maybe this weekend, If the weather is descent. Thanks for all the tips guys!
