Front Diff Drop??????
Discussion in 'Suspension' started by 05tacoSPORT, Jan 27, 2010.
  1. Jan 27, 2010 at 6:46 PM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I put a 3in lift on my taco. I had vibs in the rear end and i think i fixed it by installing a Carrier Bearing Drop. I also just got my front diff drop from toytec. Should installing this help from damage to my front end? Who has installed this after a lift and who did not? Is it a must. Next ? UCA do i need to start saving for this upgrade also? What are the best UCA for the $$$$$$
  2. Jan 27, 2010 at 6:49 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    yes they do decrease wear in the CV axles because they arent at such a high angle opposed to not having them, i would highly recommend putting them on, its only 2 bolts and will save you some $ in the long run. i put them on my truck when i put my 3" lift on
  3. Jan 28, 2010 at 11:03 AM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    09 BSP SR5 DC 4x4
    285/70/17 Dynapro MTs, Shrockworks front bumper, Armortech rear bumper
    They ought to call them a diff tilt spacer instead of a diff drop kit. Keep everything on your front end at 2.5 in and clearance what is needed and everything should be kosher. Most aftermarket skids wont work with the diff drop installed. The point has been argued in depth.
  4. Jan 28, 2010 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Personally, I wouldnt install it unless you have vibes from the front. It only changes the angle at most 2*. Many people have had vides happen AFTER installing the diff drop (tilt)
  5. Jan 28, 2010 at 11:57 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2 my vibes are all from the rear not the front
  6. Jan 28, 2010 at 7:26 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Well I did the install this afternoon and i think you are right chris. I seem to have a very slight vib at about 20 to 25mph give or take. I hope i will get my tires this weekend and they will def. make the ride a little ruff. Should i take the Drop''tilt'' off or just leave it be.
  7. Jan 28, 2010 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If there were no vibes before, I would take it out.
  8. Jan 28, 2010 at 7:33 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Will do thanks for the help
