Front diff drop
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bryce Dahlstrom, Dec 7, 2022.
  1. Dec 7, 2022 at 11:54 AM
    Bryce Dahlstrom
    Bryce Dahlstrom [OP] Well-Known Member
    Bryce
    2003 Toyota Tacoma
    Just 1.25 inch spacers so far
    I’m planning on installing a front differential drop kit with my new lift and it looks fairly easy. However I just wanted to make sure that it’s the same procedure for a manual Tacoma. I can’t find any video of people installing a diff drop on a manual Tacoma and was wondering if anyone on here has experience with this.
  2. Dec 7, 2022 at 12:19 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    By Manual you mean Transmission or Locking Hubs ?
    Having done Automatic to manual swaps The front driver shafts are the same
  3. Dec 7, 2022 at 12:43 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Waste of time and money, people still rip axle boots with it. Just do the bootslide mod instead.
    Area51Runner and TS4x4 like this.
  4. Dec 7, 2022 at 1:10 PM
    Bryce Dahlstrom
    Bryce
    2003 Toyota Tacoma
    I have a manual transmission
  5. Dec 7, 2022 at 1:34 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Kinda depends on the lift. If you have more than 2-2.5" lift, I'd definitely consider one. Less than that and I probably wouldn't bother.
    I'm of the mind that it's a cheap and easy thing to install that makes the CV angles *better*. I put one on with ~2" lift because I have mid-travel shocks so I wanted to minimize CV angle at the increased droop.
    One drawback is it will push your diff down so it will contact the skid plate unless you put in some spacers. Some kits come with spacers. I was making a custom skid plate so I didn't bother with one of those kits.
    The other option is high angle CVs which are quite a bit more expensive.
  6. Dec 7, 2022 at 5:22 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
  7. Dec 7, 2022 at 6:36 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    For a street driven truck a diff drop can extend the life of the boots.
    That’s pretty much the only benefit.
    TACOMAFORLIFE68 likes this.
  8. Dec 7, 2022 at 6:39 PM
    Nano909
    Xcab 3.4 4wd 5MT
    False. There's no benefit.
  9. Dec 7, 2022 at 6:42 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    If the pleats touch they wear. A 1/2” drop can be enough to separate the pleats at ride height.
    That being said I have 5 various 1st gen Toyotas and I do not run a diff drop on any of them.
  10. Dec 7, 2022 at 6:43 PM
    Nano909
    Xcab 3.4 4wd 5MT
    I've seen MANY diff drops on mall crawlers that still rip boots. It's 100% a waste of time and money.
    Bootslide mod > extended travel axles > driving with ripped boots for 3 years > diff drop
  11. Dec 7, 2022 at 8:15 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I have run a diff drop on my truck (WAYYYY BACK in the day when you had to make your own cause there wasn't an off the shelf solution) for 30k ish, and then got a Demello skid plate which doesn't work with a diff drop. Since then (100k+ miles) I have only blown through OEM boots once. Running around 3" of lift.
    IMO the diff drop is unnecessary.
    I will also add, that I regularly rinsed the truck and suspension components after wheeling trips to remove the dirt/sand/etc... :notsure:
  12. Dec 7, 2022 at 11:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Without getting on a soapbox too much as some have done here, the only time a diff drop is appropriate is to lower the diff enough to stop the ribs from rubbing. That's it.
    The real fix of course is to run a little less lift in the first place so you don't have as much axle angle. This is the only true way to prevent your cv boots from tearing. Diff drops and boot slide mods only mask the problem and are very poor solutions.
    Diablo169 likes this.
