front diff fluid change
Discussion in 'Technical Chat' started by sparkystaco, Mar 4, 2010.
  1. Mar 4, 2010 at 10:14 AM
    sparkystaco
    sparkystaco [OP] Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    is there a sticky or thread anywhere on changing front diff fluid, have searched and can't seem to find one
  2. Mar 4, 2010 at 11:27 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Mar 4, 2010 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What He said ^^^^ Use a 10 mm hex socket. If the fill/drain plugs are tight, tap on the wrench with a hammer to help break them free.
  4. Mar 5, 2010 at 12:04 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Trying this today. Same amount of gear oil in front and rear???
  5. Mar 5, 2010 at 4:36 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    front diff only uses 2 quarts IIRC
  6. Mar 5, 2010 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    1.6 ;)
  7. Mar 6, 2010 at 6:55 PM
    FreeHeel
    FreeHeel Not Dead But Definitely Dying
    Rambler
    2006 Reg Cab 4x4
    I just finished up changing mine (front diff) along with the rear diif, transfer case and manual tranny. On my rig (2006 4x4, 2.7L Reg Cab) both the drain and fill plugs were on the drivers side of the front diff.
    As mentioned, they take a 10m hex/allen to remove. The head s of the bolts themselves are pretty big (probably 24mm or so) so they are easy to spot.
    If you have a decent amount of miles on the truck and/or any corrosion underneath due to salt etc. hit both of em up with some PB Blaster or similar numerous times a few days before you plan on doing the service.
    As always, make certain you can break free the fill plug BEFORE you loosen the drain plug and drain the oil.
    With my rig (salt belt ughhh!) I highly doubt I could have broken the bolts free with an L shaped allen wrench. I used a 10mm hex/allen socket attached to a 24" breaker bar.
    It's a pretty easy breezy job once you have both the drain and fill plugs broken loose.
