Front diff nightmare. Please lend some advice.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ronnietacoma99, May 20, 2015.
  1. May 20, 2015 at 5:58 PM
    Ronnietacoma99
    Ronnietacoma99 [OP] Well-Known Member
    Ronnie
    Georgia
    99 SR5 4x4 2" lift 32"s
    Small maybe 2" lift, 32 x 11.50 mud terrains, TRD dual exhaust, train horns with compressor built in the tool box, 2 12a and a system that will blow your mind, new cvs
    So due to my mindset when it come to maintenance, which is "if I don't do it myself it's probly hasn't ever been done" I decided to change my front and rear gear dope. I used Lucas 75w 90 full synthetic gear lube. The issue now is that my front diff is leaking pretty bad, like a puddle the size of an iPhone 5 every time I park my truck. I thought it might be the drain plug so last night I pulled it and added some RTV to both sides of the copper washer and refilled it with another $30 worth of Lucas. Which is still slowly leaking on my driveway. Any advice would be much appreciated. I drive my Tacoma almost 100 mile a day so i have to stop the leak. 1999 Tacoma 4x4 3.4
  2. May 20, 2015 at 6:02 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    maybe get a new drain bolt and crush washer? I hope you didn't crack something by overtightening
    Rmodel65 likes this.
  3. May 20, 2015 at 6:16 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Look like the leak is coming from the seal on the right...how about you go back to plain old 80W90 dino oil?
    Howard
    koditten likes this.
  4. May 20, 2015 at 6:21 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    looks odd, but I would say washer. When I did my mine a couple of weeks ago, i re-used my washer with out issues. ...
  5. May 20, 2015 at 6:33 PM
    Ronnietacoma99
    Ronnie
    Georgia
    The drain bolt and washer both seem to be in perfect shape. They both look brand new and I tried using some Lucas that was like 85w140 and it still leaked. I'm thinking I should replace the seals. Anyone know of where I can find a write up on how to do it?
  6. May 20, 2015 at 7:03 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Did you torque it down to spec?
  7. May 20, 2015 at 10:41 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Looks like the driver diff seal. Easy to replace. Just pull the axle pull the seal put in a new one and out axle back on. Prob bout 1hr of work.
    The passenger side is a pain cause you can put the seal in too far. But the driver side has a stopper. Seals roughly $15 from the dealer and bout $5 if you have time to find it online.
  8. May 20, 2015 at 10:53 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I take it there was no leak before you changed the gear oil? Have you cleaned off the excess to determine exactly where the leak is coming from? Seems like the most likely candidate is the drain plug, if all you did was change fluid. I would clean everything up, check it in the morning to see where the leak originates from, then go get a new copper washer for the drain plug if that's what it is. I want to say the torque spec is 29 ft-lbs, too lazy to look it up right now.
    bjmoose likes this.
  9. May 21, 2015 at 7:32 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Dont think its a drain plug leak. You can see that there is gear oil leaking from above the drain plug down.
  10. May 21, 2015 at 7:45 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    If your truck wasn't leaking before you did the front diff flush, id say its something simple like your diff breather is stuck. You overfilled with fluid, and now when the diff warms up it creates pressure. The pressure can only escape through the axle seals.(instead of breather) Check the diff breather.
    I hope this is the case. this would be a much easier and faster fix than replacing axle seals.
    bjmoose likes this.
  11. May 21, 2015 at 3:30 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    axle seal, and is possible that breather is clogged causing fluid to leak out of the axle seal or it just worn out and finally give on you.
  12. May 21, 2015 at 4:17 PM
    Ronnietacoma99
    Ronnie
    Georgia
    Yea I'm going to try to install new bearing and seals and a new breather this weekend. Anyone have advice of the bearing? I'm doing them because I started hearing what I believe to be a bad bearing on the way home today, and I can grab the drivers side cv axle and it moves more than I think it should.
  13. May 21, 2015 at 5:20 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    Was it a straight forward drain and fill? it shouldn't be leaking that much just because you put synthetic oil in there unless you had to pop the axle loose during your work. I know when putting my axles back in after my diff replacement, it all looked seated but had a few milimeters left to completely seal. leaked like yours.
  14. May 21, 2015 at 5:47 PM
    Ronnietacoma99
    Ronnie
    Georgia
    No I just drained it and refilled it. It didn't leak until I gave the entire underside a purple power and pressure washer bath
  15. May 26, 2015 at 1:15 PM
    opteron
    whittier, CA.
    2003 DB 4x4 SR5
    Not sure if you resolved it, but looks that you swapped the fill plug to drain plug and vice-versa. Again not sure if it would matter.
  16. May 27, 2015 at 12:07 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    You need the needle bearing puller from ECGS, in order to do the needle bearings. In which ECGS does not machine it properly to fit between the spider gear and needle bearing. It requires some "machining" in order to slip in between the 2. Your best bet is to find someone who has already done it for a first gen and use theirs. Mine took about 45 minutes to change.
  17. May 27, 2015 at 12:22 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Just replace the leaky seal and be done with it. Why replace perfectly good bearings (assuming you have no noise concerns)? You are only asking for trouble if a simple leaky pinion seal has you baffled. Remember this, oil leaks down. Not up.
  18. May 27, 2015 at 3:57 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    He just said he has a noise....and He's not replacing the pinion bearing. It's the needle bearings that need to be replaced. And what does oil leaking down, not up have to do with anything?
  19. May 27, 2015 at 4:01 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    i got my money on this^^
    seal.
  20. May 27, 2015 at 4:09 PM
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Yeah id say seal too ,but also check your breather, My rear has leaked in the past from the end when i forget to clean the breather.
