Front Diff noise after changing oil.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoworld8, Mar 10, 2020.
  1. Mar 10, 2020 at 5:56 AM
    Tacoworld8
    Tacoworld8 [OP] Member
    Cody
    2005 Tacoma TRD Sport 4x4
    Recommendations needed! I have a 2005 trd sport. I changed my front, rear, and transfer case with Valvoline (which has slip additive in it). It sounds like gears are grinding (chatter) in the front (but has only done it twice when turning at low speeds). Just worried about driving it or if I should change the oil again with something else. It has only done it twice. Should I change it again with an additive or a different brand?
  2. Mar 10, 2020 at 6:00 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Are you turning while in 4WD?
  3. Mar 10, 2020 at 6:08 AM
    Tacoworld8
    Cody
    No, it isn’t in 4 wheel drive. Just normal. I’m pretty sure it’s coming from the front.
  4. Mar 10, 2020 at 6:18 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    What weight gear oil did you use?
    -J
    Tacoworld8[OP] likes this.
  5. Mar 10, 2020 at 6:34 AM
    Tacoworld8
    Cody
    75w90 valvoline with slip additive.
  6. Mar 10, 2020 at 6:41 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Why did you change the oil? I have a suspicion there is more to the story here
  7. Mar 10, 2020 at 6:45 AM
    Tacoworld8
    Cody
    It was just regular maintenance as most people do every 30,000 or so.
  8. Mar 10, 2020 at 6:47 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I doubt it’s the oil. I used that in my 14 with no issues. Maybe check the oil level again?
  9. Mar 10, 2020 at 6:49 AM
    Tacoworld8
    Cody
    I did. I actually went and topped it off to make sure it wasn’t low. I have read from some others that they have had the issue also and then changed it - and it stopped. Some also say that different brands cause chattering more so than others. I just don’t know that much about the diff to understand.
    NAAC3TACO likes this.
  10. Mar 10, 2020 at 6:53 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Might want to check your wheel bearings, maybe that's the noise your hearing.
  11. Mar 10, 2020 at 6:54 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    2nd gens get all three gear oils filled until it just barely starts to overflow through the fill hole (parked on level ground of course). Might be worth a check just to make sure that everything is still tight and it didnt leak out.
    Moreover, might be worth taking a step back and thinking about other things.. You said the noise was intermittent. Did you leave a rag down there somewhere? Maybe a small tool? Maybe its not even the front diff?
    Chattering as I have heard it used is typically the result of a mechanical Limited Slip mechanical being unhappy with the oil that was used (typically straight up gear without any additive). The front diffs on these trucks are full open, so that shouldn't be the issue here. Using LSD additive oil in a regular open diff shouldnt be an issue either.
  12. Mar 10, 2020 at 6:55 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I’ve only heard of chattering from the rear. Corvettes were notorious for this until GM came out with Dexron LS oil. If you’re positive it’s in the front, I would try a different oil.
  13. Mar 10, 2020 at 6:56 AM
    Tacoworld8
    Cody
    Ok, let me take her out for a short drive and I’ll reply to y’all. Thank you so much. I replaced the wheel bearings last year and they don’t have play. I checked those.
  14. Mar 10, 2020 at 6:57 AM
    Tacoworld8
    Cody
    Maybe it is back. Only heard it twice, so I’ll drive and check again.
    NAAC3TACO[QUOTED] likes this.
  15. Mar 10, 2020 at 6:58 AM
    SR-71A
    Zack
    Southern Maine
    Like I said above (you and I posted at the same time) chattering is an LSD thing. A true open diff like the front diff in our trucks shouldnt care as long as the oil weight and level is correct
  16. Mar 10, 2020 at 7:04 AM
    Tacoworld8
    Cody
    Ok, I just drove and did sharp turns. It is my rear. I think I need additive. What brand do y’all recommend? Should I just get toyota brand? Or autozone?
  17. Mar 10, 2020 at 7:05 AM
    Tacoworld8
    Cody
    And do you lift yours off the ground to fill or do it just on level ground?
  18. Mar 10, 2020 at 7:05 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Just get 4oz of limited slip additive. Brand shouldn’t matter.
    3JOH22A likes this.
  19. Mar 10, 2020 at 7:05 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    Really, like who? Is it a common theme because I think I hear it too, and I just changed mine a couple weeks ago and have been wondering the same.
  20. Mar 10, 2020 at 7:12 AM
    Tacoworld8
    Cody
    Do y’all use full synthetic or just high performance?
