Front Diff Noise & Vibrations - Needle Bearing - Fixed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DLillest, Jul 6, 2020.
  1. Apr 9, 2023 at 8:35 PM
    Puhpintaco
    Puhpintaco Member
    O.C. CA.
    2014 Grey Tacoma 4x4
    ICON Coil Overs , Upper control Arms , Rear Shocks . Method 703s 17" with BFG 285/70/17s.
    I had my CV axles rebuilt due to a clanking , knocking and grinding noise from my front end.
    The noise still there , but not as severe as before the rebuilt CVs, but still... It occurs at slow speeds, when braking and turning.
    I returned to the shop that rebuilt the CVs and they couldn't fix the problem. Could improperly aligned CVs cause the noise issue?
  2. Apr 10, 2023 at 3:54 PM
    BlueTaco9486
    BlueTaco9486 Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    Do you have a lift on the truck? If you have more than 2 inch lift you may need to put spacers under the differential to straighten out your CV axels with your wheel hub. I had to replace a bearing in my differential in the driver side. That stopped the grind/clunk noise for me.
    Puhpintaco likes this.
  3. Apr 10, 2023 at 6:30 PM
    Puhpintaco
    Puhpintaco Member
    O.C. CA.
    Thanks for your reply. I have an ICON lift on it. I don't know how high or if I have spacers to straighten out the axles. I'll inquire about the wheel bearing. Is part of the axle rebuild or should be done in addition too?
    Regards
    JJD
  4. Apr 10, 2023 at 7:09 PM
    BlueTaco9486
    Bunk
    2013 Blue Taco
    Not wheel bearing, it’s the needle bearing in the front differential. Grab your cv axle on the driver side and give it a tug. If it moves where it goes into the differential you probably need a new one. Try upgrading to the bushing from east coast garage. https://youtu.be/nllcwqI1YVI
    Puhpintaco and G2.M6 like this.
  5. Apr 10, 2023 at 7:16 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Sounds like Bluetaco has your back. Thank you TW member.
    BlueTaco9486[QUOTED] likes this.
  6. Feb 6, 2024 at 9:12 PM
    Lucas2297
    Lucas2297 Member
    Lucas
    2018 Tacoma SR5
    JD Fab LT kit, Lower Pivot Kit
    Gentlemen, I’m coming across the same issue while in 2wd, slight humming/ vibrating feeling coming through the floorboard. I’m trying to troubleshoot, I know if you out it in 4wd the noise/feeling should go away. In my case when I throw it in 4wd it gets significantly louder. Could this still be the needle bearing or could it be a more serious issue inside of the diff. Thanks for the help in advance guys!
  7. Feb 7, 2024 at 2:46 PM
    545
    545 Well-Known Member
    2015 Access Cab
    Check all your ujoints
  8. Feb 7, 2024 at 9:18 PM
    Abdulla
    Abdulla Active Member
    1 Inc lift / 285/75/16
    Where can I get these east cost garage bushing in dubai Im Tired trying to explain to mechanics hhh
    Or what is the exact size of it if I would to fabricate it myself HELP!
    It's 2018 trd off-road- access cap
  9. Feb 9, 2024 at 3:44 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
  10. Feb 9, 2024 at 3:57 AM
    Abdulla
    Micbt25[QUOTED] likes this.
