Front Diff oil?
Discussion in 'Technical Chat' started by lipripr, May 27, 2009.
  1. May 27, 2009 at 4:45 PM
    lipripr
    lipripr [OP] Member
    Colorado
    2006 TRD 4x4
    I changed my rear diff and trans case oils, but couldn't loosen the damn fill plug in the front diff (glad I tried before draining) Is it ok to have new fluid rear and t/c and not in the front Diff, or am I going to mess something up? thanks
  2. May 27, 2009 at 4:47 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    you should be fine, but you might wanna keep a schedule of this, and change all at once
  3. May 28, 2009 at 1:58 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    I had the same thing happen to me at my last oil change. Changed the rear end, transfer, & engine oil, but for the life of me, I could not get the fill plug off for the front diff! I started to work on it, but that hex socket started to slip on me so I didn't go any farther. I didn't want to strip that thing out. So I'm gonna give it another try this weekend when I change out the engine oil. Wish me luck!:eek:
  4. May 28, 2009 at 1:59 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    can someone tell me the size of that damn hex?
  5. May 28, 2009 at 2:11 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Is it 24mm like the others?
  6. May 28, 2009 at 3:50 PM
    monoman
    Dave
    It's 10mm or 12mm hex, can't remember - anyone else?.....24mm socket is for the rear I know that much....
  7. May 28, 2009 at 3:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I don't remember who but another guy had the same problem on the fill plug. He couldn't get it off now matte what he tried! I remember he was really pissed. Not sure what he did finally to get it off.:rolleyes:
  8. May 28, 2009 at 3:53 PM
    DanGer
    No its a hex, the rest are garden variety 24mm sockets
  9. May 28, 2009 at 3:56 PM
    JM76
    JM76 Ride On
    Jon
    SC
    06 silver double cab 4x4
    seconday air filter removal, tw sticker afe pro dry s filter , black rims , cb radio with four foot firestik antenna,black nasta nerf bars,5100's in the rear,mp3 player hookup,led overhead light,5100's up front @ 1.75, rear AAL,custom dent package,blacked out rear bumper, blacking out front grille,camo gt seat covers , 6k HIDs, 6k fogs coming, devil horns grille mod,elite offroad aluminum bumper,Canadoshi grille mod.light bar behind the grille with bright lights coming sooner or later
    10 mm socket...had to buy a set just to get the one.
  10. May 28, 2009 at 3:57 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    So did you change out your front diff oil as well?
  11. May 28, 2009 at 4:00 PM
    DanGer
    Front diff and driveshaft grease are the only things left on my 30k that I couldnt get done
  12. May 28, 2009 at 4:02 PM
    JM76
    JM76 Ride On
    Jon
    SC
    indeed, did it about 6k ago....along with plugs, etc.
  13. May 28, 2009 at 4:16 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Any secret on getting off the front diff plug?
  14. May 28, 2009 at 4:19 PM
    DanGer
    my next attempt is going to include spraying that thing with PB blaster with the zeal i had on losing my virginity.
  15. May 28, 2009 at 4:20 PM
    DanGer
    but this time i am NOT going to tell the fill plug I want to just put to tip of my tool in
  16. May 28, 2009 at 4:22 PM
    JM76
    JM76 Ride On
    Jon
    SC
    uhhhh.......use an extension, and put your ass in it, if you will. It wasn't that hard, and I am by no means mechanically inclined.
  17. May 28, 2009 at 4:25 PM
    JM76
    JM76 Ride On
    Jon
    SC
    fixed it, SICKO!!!:eek:
  18. May 28, 2009 at 4:30 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    long extension, long handle ratchet (or cheater) 3-5 lb. deadblow hammer. i thought i was gonna pull my truck off the lift when i first tried it. held everything tight and gave it a few good whaps, and presto.
  19. May 28, 2009 at 4:36 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Sweet!
  20. May 29, 2009 at 1:38 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I recently greased the drive shafts. The rear 2 u-joints took 1 pump and the grease squished out. The front u-joint took 3 pumps until anything squirted out. I guess its good I greased that front u-joint.
