Front Diff passenger side needle bearing failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Austintaco, Jul 25, 2020.
  1. Jul 27, 2020 at 5:56 PM
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    How frequently are folks doing the passenger side ECGS solution? It doesn't seem like this creates as many issues. I'm looking at doing my needle bearing, replacing the CV axle, and the hub/bearing assembly. I'm pretty sure it is the bearing that is giving me the humming at 20-40mph as it does not go away with 4wd, but the CV is needing replacement. My truck has 2.5" of lift so I guess it makes sense to do the needle bearing elimination.
  2. Jul 27, 2020 at 6:32 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Seems to be more common for 2nd and 3rd gens but that may just be because people with newer trucks have a lower tolerance for vibrations and such.
    If you're going to be replacing the needle bearing anyway I would 100% do the ECGS bushing in it's place
  3. Jul 27, 2020 at 6:50 PM
    Bwthomas77
    North Carolina
    I'm sold on the needle bearing elimination. ECGS has a passenger side solution as well (which doesn't get talked about as much on this forum) - did you do that one when doing the driver's side needle bearing elimination?
  4. Jul 27, 2020 at 7:09 PM
    eon_blue
    Azusa, CA
    I haven't done either yet but plan on the driver's side one eventually.
  5. Aug 12, 2020 at 2:19 PM
    Bwthomas77
    North Carolina
    Well I finished this project.
    The needle bearing had some wear and metal shavings. I just posted about this in the second gen forum.
    Everything is better.
    I did not replace the passenger side bearing. I bought it, but returned it as it looked like it would be unnecessary.
    Warthog73 and cruiserguy like this.
