front diff pop upon disengagement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shift3y5b, Nov 25, 2010.
  1. Nov 25, 2010 at 6:40 AM
    shift3y5b
    shift3y5b [OP] New Member
    llano, tx
    06 tacoma 4.0 4x4
    3" lift, borla exhaust and air intake. custom leather seats.
    Hello TW, I love the forum. I am a pretty new taco owner ( 06 long bed, crew cab, 4x4 trd sport, with 3" lift. I have only had the truck for 6 months and It's the best truck i've ever had. I installed the lift without doing research and then found out the spacers are not a good choice. I will install 5100's soon. I recently took the truck to colorado in the mountains and used 4wd a lot. I noticed a pop in the front diff while disengaging to 2hi. The light blinks for a minute, then you hear and feel a pop. Is this normal? It works great while in 2hi or in 4wd, just makes noise when you take it out.
  2. Nov 25, 2010 at 11:52 AM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    ya mine did the same, asked the dealer and they said make sure to be coasting not accelerating when you disengag. hasn't done it since
  3. Nov 25, 2010 at 11:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yup...When you go to 2HI the actuator has to separate the gears in the front...If they have a load on them or the timing is just right there can be some tension left in there and they will pop when they pull apart.
    No big...That coasting trick will help too...
  4. Nov 25, 2010 at 12:08 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^
  5. Nov 25, 2010 at 12:10 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I just give it a bit of gas then take my foot off the pedal before making the switch back into 2wd...no clunk noise!:)
  6. Nov 25, 2010 at 12:11 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Try not to disengage while on the gas or turning. Ideally, engage/disengage 4WD while going in a straight line and coasting.
    That said, this is no big deal. The system is built to handle this stuff.
  7. Nov 25, 2010 at 3:26 PM
    shift3y5b
    llano, tx
    06 tacoma 4.0 4x4
    thanks everyone, that answers the question. Both times it did it, I was coming down off the mountain and was engine braking, so it makes since. I was just concerned as I did not hear it before. I hope to post pics of my taco soon.
