Front diff question
Discussion in 'Technical Chat' started by loggerpete, Apr 19, 2009.
  1. Apr 19, 2009 at 1:15 PM
    loggerpete
    loggerpete [OP] Member
    The level is correct in my front diff but oil still comes up through breather.
    I took off the small hose that connects the diff to the breather hose and there is oil seaping out of the diff.If there isn`t pressure and the oil level is correct then why is oil coming back up? And thats without it moving for 12 hours too.This is driving me nuts.
  2. Apr 19, 2009 at 1:22 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    What year Tacoma? But honestly, I'm scratching my head on this one. The differential isn't under any air pressure and it shouldn't be oozing out of the breather vent, did you do anything reciently to the diff? Just give it a while, someone here will know. I changed mine with no problems. Be patient.
  3. Apr 19, 2009 at 1:30 PM
    loggerpete
    I changed driver side axle seal cause it was leaking and the actuator silicon.I drove it for two days then noticed the oil still leaking so thats when I cut the small breather hose off and noticed the next morning oil coming up through the small tube on top of the diff .
  4. Apr 19, 2009 at 2:54 PM
    Monkeysuncle
    Kevin
    Florida
    I have a 1999 with manual hubs, nothing automatic as far as 4x4 is concerned. I get out lock in the hubs then shift into 4x4 whenever I want. Is your truck new? Just turn a switch and viola 4x4? That might be the source of the problem. Auto hub v.s. manual hub. Are you having trouble in 4x4?
  5. Apr 21, 2009 at 6:31 AM
    loggerpete
    No trouble with 4x4 at all. The oil just wants to come back up breather hose although oil is at right level and there is no pressure.
