Front Diff Questions
Discussion in 'Technical Chat' started by dmblongo, Mar 9, 2010.
  1. Mar 9, 2010 at 8:37 PM
    dmblongo
    dmblongo [OP] Member
    Colorado
    05 TRD DoubleCab
    I know there are some posts regarding similar issues but I wanted to make sure my diff doesnt grenade while driving down the road.
    05 DBL Cab OR drove perfect until the installation of the 3" toytec last week (one piece DS, 3 degree shims, front diff drop) 65k miles. Ever since I have the common front diff hum (sounds harmonic to me) between 5-40 mph. As soon as 4x4 is engaged sound is gone and drives smooth as glass.
    My questions
    1. When spinning the Drivers side wheel you can hear the spyder gears clicking inside the front diff, passenger side is quiet.
    2. Is it still safe to drive without damaging the diff?
    3. How hard is it to change the drivers side bearing if needed? Pressed in? Diff removal?
    4. Is there any easy way to check the bearing other than play in the shaft? I know some play is normal could it be the clip on the end of the shaft?
    5. Does anyone have pics of the inside of the diff or the bearings that are good/bad?
    Thanks in advance!
  2. Mar 10, 2010 at 6:55 PM
    dmblongo
    Colorado
    05 TRD DoubleCab
    Anyone?
  3. Mar 10, 2010 at 7:00 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    some one will chime in...
  4. Mar 11, 2010 at 8:21 AM
    dmblongo
    Colorado
    05 TRD DoubleCab
    Breakfast Bump...
  5. Mar 11, 2010 at 8:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    A harmonic hum is more than likely a bearing. Spider gears shouldn't be clicking. I think you might actually be hearing the bad bearing in the diff.
  6. Mar 11, 2010 at 8:30 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Look for a thread by Krookz. Iirc he had a similar problem with his truck and he figured it out. I think it was the seals maybe?
  7. Mar 11, 2010 at 9:59 AM
    dmblongo
    Colorado
    05 TRD DoubleCab
    Thats what I'm afraid of. I have heard the drivers side is a PITA....have any feedback on that? :confused:
    I have been looking around but I can't seem to find anyone with pics or removal/install info either. It's not leaking anywhere so I didnt think it was a seal issue...stranger things have happened though.
  8. Mar 11, 2010 at 10:07 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I don't think there is a DIY for that on the board. Most get it addressed under the power train warranty. Toyota normally replaces the entire diff.
  9. Mar 11, 2010 at 10:10 AM
    dmblongo
    Colorado
    05 TRD DoubleCab
    Well crap...that leaves us used owners with 65k out on the street. Hopefully someone comes up with something...
    Thanks for the help thus far..
