Front Diff Rear Oil Seal Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by BVCOTaco, Feb 28, 2012.
  1. Feb 28, 2012 at 4:01 PM
    BVCOTaco
    BVCOTaco [OP] Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I have been seeing some minor leak coming from the front end of my truck. It was a minor leak until I drove 3 hours this past weekend. When I got home there was quite a bit of oil around the front suspension. So this afternoon I finally got around to cleaning up some of the oil and went for a drive to try and pin point the leak. It looks like the rear oil seal on the front diff is leaking. Actually it looks like the oil seal at the rear drive shaft to the transfer case is also leaking. I was looking through the factory service manual files and it looks like it shouldn't be to hard to change out.
    Does anyone know of any write ups on changing the oil seals?
    I had this happen on my old Jeep and it was really easy to change, but the access was way easier with the solid front axle.
  2. Feb 29, 2012 at 5:44 AM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    Bump
    Does anyone know if you can just pope the oil seal out with a screwdriver? Or is there some special puller tool you need?
  3. Mar 14, 2012 at 10:09 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    did you even finish this? im having trouble getting the seal in
  4. Mar 14, 2012 at 11:26 AM
    BVCOTaco
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I actually brought my truck into the dealership to get the timing belt and water pump changed out, so I am having them change the oil seal for me. I am having problems with a leaking power steering rack as well, so that is also getting changed out.
    Sorry I couldn't be of any help!
