Front diff removal: is it a nightmare?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Apr 10, 2014.
  1. Apr 10, 2014 at 8:08 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Moved the truck this am to go to work and saw a good size oil spot under the front of my tacoma. First time I've had a drop leak from this truck. Made sure the filter was tight so I know it's not that. Some of the bolt heads holding on the oil pan along the drivers side had drops on them so I'm suspecting my oil pan gasket is leaking.
    In order to drop the pan I noticed my pumpkin is in the way. Is it a nightmare to get that pan out? Any DIY on removing the front axle housing/diff? If the truck wasn't paid off I'd consider getting rid of it. Thanks guys.
  2. Apr 10, 2014 at 8:17 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I would like to know this as well. My oil pan gasket seems to be leaking also. Not dripping yet, but it's wet around the outside.
  3. Apr 10, 2014 at 8:22 AM
    Trapperr
    Reno, NV
    I should add that I also checked the valve cover gasket on both sides to make sure it wasn't that dripping down to lower part of the engine.
  4. Apr 10, 2014 at 8:57 AM
    JR motard
    JR motard Active Member
    Rolla/Kansas City, MO
    96 v6 4x4 Xtra cab tacoma
    not too bad to do. I (luckily) had access to a lift. Was doing rear main seal, figured i'd do oil pan seal as well. Probably did it the wrong way but it seemed the easiest to me. it also helped to have tranny out but you wont be doing that.
    Anyways: had truck in air, unbolted front diff and pulled it down as much as possible, removed front driveshaft, then unbolted oil pan and oil pickup, then managed to snake the pan out. i didnt want to pull axles cause i have manual front hubs. it worked.
    no more leaks.
  5. Apr 10, 2014 at 9:00 AM
    Trapperr
    Reno, NV
    That doesn't sound bad at all! How many bolts hold the diff in place? Do you need an alignment after messing with the front diff(sorry if that's a dumb question)? About how many hours? I don't have help so I'll be going at it alone.
    I may end up PM'ing you on the rear main seal replacement as I only want to do this once haha
  6. Apr 10, 2014 at 9:06 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    diff only has 3 bots holding it up.
    gotta take the skids off.
    Id just pull the axles, Isn't hard to do. You could use the oprotunity to put new gear oil in.
    Once the CVs are pulled whole thing will come right out after the drive shaft is unbolted.
  7. Apr 10, 2014 at 9:14 AM
    Trapperr
    Reno, NV
    Thanks blackdawg. Once the cv's are popped out, is that C-clip on the diff end toast or can I just pop the cv back in no problem when I reinstall?
  8. Apr 10, 2014 at 9:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just pop it back in. Shouldn't be an issue.
  9. Apr 10, 2014 at 9:37 AM
    Trapperr
    Reno, NV
    Much appreciated blackdawg
  10. Apr 10, 2014 at 3:50 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    just don't ding the diff seals at each end of the diff where the cv's click in. Also that thing is a bit off balance so be ready for it.
  11. Apr 10, 2014 at 3:54 PM
    Trapperr
    Reno, NV
    My plan was to put a floor jack under the pumpkin and use that to support as I lower and move the front diff. Then when it's out of the way enough I was going to use a couple jack stands on the axle tube to hold it while I do repairs.
  12. Apr 11, 2014 at 2:27 PM
    Trapperr
    Reno, NV
    Good news is I MIGHT not have to drop the pan.
    Bad news is it could be the rear main seal. The leak seemingly stopped as there was no new oil this morning under my truck. Well when I went to lunch today there was a half-dollar size spot. Crawled under again and I could see a drop of oil hanging off the front of the bell housing.
    The fun never ends!!
  13. Apr 11, 2014 at 2:29 PM
    Large
    Large Red
    Not sure about first gens but 2nd gens isn't too bad if you have another set of hands (I managed by myself). Just remember to get new diff oil when you pull the CVs out.
  14. Apr 11, 2014 at 7:42 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    yeah my rear main has been leaking since i got my truck. doesnt drip any oil, but the whole back half of the pan is wet
