Front diff seal replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by dankgus, Aug 24, 2019.
  1. Aug 24, 2019 at 8:17 PM
    dankgus
    dankgus [OP] Well-Known Member
    Dan
    2002 3.4l Tacoma
    I've got the seals in hand and the diff is drained. The truck is jacked up and I've got the passenger side wheel removed as well as the 35mm axle nut.
    All the instructions on the web say to disconnect the tie rod at this point but I'm having some trouble. I borrowed a tie rod remover but it's just too bulky to fit over the assembly. The nut is removed of course.
    Any advice on disconnecting the tie rod?
  2. Aug 24, 2019 at 8:19 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Are you using a fork or a puller? Maybe try an adjustable puller. FYI, if you have any of the big name auto parts stores near you, you can rent a puller set for free, typically.
  3. Aug 24, 2019 at 8:27 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    I'm using the puller variety that looks like a U with a bolt through it.
    I feel like there's a CHANCE this puller could work if I put the wheel back on and lower the truck. That would give me a little more clearance.
  4. Aug 24, 2019 at 8:29 PM
    SC4333
    Grant
    FL
    Unfortunately i've only had 2nd gen and now a 3rd gen tacoma, so I cant really speak for the 1st gen. I have pulled many a tie rod though and if worst comes to worst, i'd try a different puller if you feel like you can get something else in there. Or hit it with a fork, but then you risk damaging the boot.
  5. Aug 24, 2019 at 8:57 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    Ok no fork, I don't want to tear the boot. It's interesting as I go down the YouTube rabbit hole of tie rod removal, a LOT of people seem to suggest a few good whacks with a hammer. I suppose it's worth a try. There's even a specific Tacoma video of a guy doing it.
  6. Aug 24, 2019 at 9:32 PM
    SC4333
    Grant
    FL
    I would give it a shot. I’ve got away with hitting quite in the past without issue. Just be sure to hit it as square as possible and you’ll be alright. Worst case senecio you good up a thread and chase the threads with a die.
  7. Aug 24, 2019 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The next step is to disconnect the lower ball joint bolts. No need to disconnect the tie rod. Then just swing the spindle out of the way. The axle will slip out of the wheel bearing.
  8. Aug 25, 2019 at 10:10 AM
    Glamisman
    Glamisman Well-Known Member
    Using 2 hammers, put one behind the joint housing and hit the joint housing on the opposite side and it SHOULD pop out. Dont hit down on the threads of the joint.
  9. Aug 25, 2019 at 10:33 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Hammer and buck always works on tapered studs right up till the time it doesn't.
    I use and carry a puller that fits, much much quicker than proper r+r of the LBJ bolts. I avoid disturbing LBJ bolts unless necessary.
    Home and purse sizes.
    CS_AR and 0xDEADBEEF like this.
  10. Aug 25, 2019 at 10:36 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Do you have a brand and part number on those? I see this work in my future and my puller collection is lacking.
  11. Aug 25, 2019 at 10:47 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    That's a nice wide puller. Will it also clear the upper control arm to pop out a UBJ?
  12. Aug 25, 2019 at 10:54 AM
    dankgus
    Dan
    2002 3.4l Tacoma
    Thank you for this bit of information!
    I thought "what have I got to lose besides some time" so I removed the 4 bolts at the lower ball joint and gave it a whack. Once the lower ball joint was disconnected I was able to BARELY get the tie rod separator over the joint any pop it loose. While the job is technically possible without disconnecting the tie rod, man it would suck a lot more.
    I have the axle almost removed at the moment (splines exposed at both ends) I think I may need to disconnect the sway bar so I have enough clearance to get the axle out.
  13. Aug 25, 2019 at 10:58 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Sorry they are both 40-50 years old, both USA made. The tall one (with two ranges) is "Cal something" from a chain store of the day and the smaller fellow is Snap On. I did grind the tips (thinner) of the Snap On to avoid any trauma to 1st gen boots.
  14. Aug 25, 2019 at 11:02 AM
    0xDEADBEEF
    Nice. That seems to be the only problem with tools that last, you never can get more of them.
    Dirty Pool[QUOTED] likes this.
  15. Aug 25, 2019 at 11:08 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    No, that job gets the attention of a larger two jaw puller. On occasion I have put a Vise Grip chain wrench around the jaws to prevent it slipping off the UCA.
    Seen in the lower center below. Many of these type pullers share the same screw thread so various combinations of parts can be used.
    For r+r of the UBJ/spindle nothing beats the BINFORD ball joint kit.
    CS_AR[QUOTED] likes this.
  16. Aug 25, 2019 at 11:33 AM
    CS_AR
    Thanks for the info. I see you have some pipe supplements for the kit. That's a good idea. I pressed in some new UBJs this weekend and the only kit that could cover the UBJs length was a big Powerbuilt 46 piece kit that I borrowed from Advance auto. The next time I need to remove UBJs (hopefully some years into the future), I will want to preserve them and will need a good puller to remove them without damage.
    I bought a tie rod end puller from O'Reilly that sells for like $15.95 that worked well. I had to use a sledge hammer to pound out the UBJs this time. I didn't care what happened to them since it was all about replacing them. I did manage to press out the LBJs with the press I used on the tie rod ends. Those will be replaced also.
  17. Aug 25, 2019 at 11:44 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yep, the "assembled" length of the adapters frequently stumps folks with the common size press.
    My 1st adapter for UBJs was a ground down pipe cap. The screw pressed directly on the UBJ stud. It would press out the whole joint or pop the ball/stud clean out of the cup.
  18. Aug 25, 2019 at 2:43 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    I've got 4 bolts connecting the lower control arm/ball joint to the steering knuckle. A lot of the torque guides are listing 2 bolts at something like 116ft lbs.
    Some guides say 96 ftlbs.
    Anybody know what I should torque these 4 bolts to?
  19. Aug 25, 2019 at 2:46 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    To add to my previous post, these bolts are actually quite small. Like 10mm? I'm concerned I'm interpreting the torque specs incorrectly.
    100 ft lbs seems like a lot.
    Edited: the bolts have a 14mm head.
  20. Aug 25, 2019 at 2:53 PM
    dankgus
    Dan
    2002 3.4l Tacoma
    Just talking to myself here.
    The Toyota official fastener guide lists a bolt of this spec (class 11T, m10x1.25) as a 64 ft lb bolt.
    I'm going with this, along with a bit of blue loctite.
