Front diff temp sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blueberry.Taco, Dec 7, 2020.
  1. Dec 7, 2020 at 9:22 AM
    Blueberry.Taco
    Blueberry.Taco [OP] blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    I noticed my 2020 AC manual sport does not have a front diff temp sensor, but have seen many pictures of other (potentially older year) 3rd gens with front diff temp sensors.
    is it a model year difference or did only offroad/pros get the front diff temp sensors?
    Not a big deal, just a question out of curiousity.
  2. Dec 7, 2020 at 9:30 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    2017 Sports definitely didn't come with this.
    Skydvrr likes this.
  3. Dec 7, 2020 at 10:15 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Wiring diagram shows it but I’m not sure if it’s just for the off road and pro.
    • 26.pdf
      File size:
      44.5 KB
      44
  4. Dec 7, 2020 at 10:16 AM
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    I have a 19 OR and as far as I know I don't have one
  5. Dec 7, 2020 at 10:26 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    2016 OR manual and definitely have it. I bet y'all do too. I was under the impression it was on all 3rd gens no matter but I haven't researched it. Take pictures where it should be and we'll confirm.
    cryptolime, tacotoe and BigWhiteTRD like this.
  6. Dec 7, 2020 at 10:28 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Where does it display on your truck?
  7. Dec 7, 2020 at 10:37 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Doesn't display, unless it exceeds threshold and causes the dashboard to become unhappy with you.
    Need techstream to see its current value... (or alternatively I suppose there is a PID..)
    ShimStack likes this.
  8. Dec 7, 2020 at 10:40 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Ah okay. Then I stand corrected. I probably have it. I thought the OP was asking about a display like the inclinometer and pitch that the off-roads have.
  9. Dec 7, 2020 at 10:42 AM
    ShimStack
    Ben
    NC
    @BigWhiteTRD is right, it displays nowhere and is used to throw trouble codes only. You can read/plot the value using techstream.
    I did quick research and I couldn't confirm it's standard on *all* 4x4 2016+ trucks. It's located on the rear of the diff on the passenger side of the pinion just forward of the engine oil pan. The harness runs along the pass side axle tube before routing up to the front axle harness bracket.
    https://twstatic.net/attachments/036_banjo-jpg.4230347/
    BigWhiteTRD likes this.
  10. Dec 7, 2020 at 11:25 AM
    Blueberry.Taco
    Ryo
    SE MI
    Sorry diff is out of the truck right now so I don’t have a pic with the same angles but you can reference the ARB locker fitting for location.
    Edit: this photo sucks, I'll go out and take another photo in a few....
  11. Dec 7, 2020 at 11:32 AM
    Blueberry.Taco
    Ryo
    SE MI
    This should make it more obvious. Again, 2020 manual trans sport
    tacotoe likes this.
  12. Dec 7, 2020 at 11:44 AM
    BigWhiteTRD
    Ted
    Likewise I can't confirm all years or trims, but all the 2016 schematics show it (with no indication that it is optional).
    ShimStack[QUOTED] likes this.
  13. Dec 7, 2020 at 11:45 AM
    ShimStack
    Ben
    NC
    Did you install the ARB in your stock diff? Was there an entire clamshell swap done to do the install?
    It could be a model year thing removed from newer trucks and I guess it could be a trim level thing as well. In the factory service manual for the earlier 3rd gen trucks I can't find a mention of the front diff oil temp sensor being only on specific trims.
  14. Dec 7, 2020 at 11:45 AM
    ShimStack
    Ben
    NC
    Just beat me!! :D
    BigWhiteTRD[QUOTED] likes this.
  15. Dec 7, 2020 at 11:47 AM
    Blueberry.Taco
    Ryo
    SE MI
    Yup, ARB added to the stock diff.
    interesting.
  16. Dec 7, 2020 at 11:49 AM
    ShimStack
    Ben
    NC
    Added to *your* stock diff, correct? By you?
  17. Dec 7, 2020 at 11:50 AM
    Blueberry.Taco
    Ryo
    SE MI
    by ECGS, but confirmed it is still my own clamshell via markings i made in it prior to shipping it to ECGS
    SR-71A likes this.
  18. Dec 7, 2020 at 11:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Huh, today I learned. I had no idea this was a thing on some third gens.
    Ricardo13x likes this.
  19. Dec 7, 2020 at 11:56 AM
    ShimStack
    Ben
    NC
    You mark both halves? I'm just asking because this brings in outside variables and the diff in the 2nd gen is the exact same thing without a temp sensor. But if you pulled it out, you'd know if you had the temperature sensor connected in your harness.
    Toyota may have axed it. Haven't seen many "Got a front diff temperature warning light, what do I do?" posts. It may not have served the purpose Toyota intended. Or it's possible it's an access cab thing. I guess what I'm saying is I don't have a clue. But I've noted it.
    GilbertOz, Kev250R and BigWhiteTRD like this.
  20. Dec 7, 2020 at 11:58 AM
    Blueberry.Taco
    Ryo
    SE MI
    hm i'd have to take a look to see which half I marked, but seems like something ECGS wouldn't have any reason to mix up. I don't remember unplugging any temp sensor but that was a while ago. I'll know if i have an open plug when i go to reinstalling it soon.
