Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Apr 6, 2017 at 1:33 PM
    #221
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    500k miles is what the ECGS Clamshell Bushing FAQ says by the way...
  2. Apr 6, 2017 at 1:36 PM
    #222
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I used a 3 jaw puller with a slide hammer to remove the needle bearing on my 2nd gen way back when. But I just got the ECGS bushing for my 3rd gen and got their removal tool with it this time.
    For the HF rear axle puller I think you'd need to measure them against the bushing and housing to make sure it will work. For $60 I opted for something that I know will work
    GPsevinSixx likes this.
  3. Apr 6, 2017 at 1:38 PM
    #223
    smitty99
    Scottsdale
  4. Apr 6, 2017 at 1:40 PM
    #224
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Vibes fixed?
  5. Apr 6, 2017 at 1:41 PM
    #225
    smitty99
    Scottsdale
    Smooth as a baby's ass!!!!!!!
    ETAV8R and GPsevinSixx[QUOTED] like this.
  6. Apr 6, 2017 at 2:00 PM
    #226
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    @smitty99 How long did it take you to develop the vibrations?
  7. Apr 6, 2017 at 2:01 PM
    #227
    smitty99
    Scottsdale
    Installed a very mild 1.5" lift with bilstein 6112s, noticed it immediately upon exiting the driveway after just having lowered it off the jackstands. It happened just that quick and yes with only a very small lift.
    flash5twelve likes this.
  8. Apr 6, 2017 at 2:18 PM
    #228
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    500,000 miles.
  9. Apr 6, 2017 at 3:03 PM
    #229
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Mine took about 300 miles to notice anyway with a 2.5 lift. I read somewhere to last the life of the truck. Most won't get too 500k with the same owner but there will be a few.
  10. Apr 6, 2017 at 3:23 PM
    #230
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    I think I may just pay the 60 bucks for their tool just for peace of mind. This vibration is worrying me so I just wanna get it done.
  11. Apr 6, 2017 at 3:43 PM
    #231
    smitty99
    Scottsdale
    For $60 I agree...it is one of those jobs you just don't want to risk fucking up on. Do it once, do it right and you should be golden for the life of the vehicle. Also their instructions say to run slightly heavier grade gear oil than OEM (I believe OEM is lighter than ECGS recommendation of 85w-140) I used Lucas 85-140 based on their recommendation.
    I look at it this way. Toyota couldn't or wouldn't put in the effort to get this issue fixed with a better more permanent solution. ECGS developers figured it out and recommend a different gear oil....I'm going with their recommendation.
    JoeCOVA and GPsevinSixx like this.
  12. Apr 6, 2017 at 4:31 PM
    #232
    ievko82
    WV
    Totally agree with you. Did you have to flush all the old gear lube out or just drain it and refill? Also I take it there's no need for a friction modifier?
  13. Apr 6, 2017 at 4:35 PM
    #233
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    The heavy Lucas gear oil that's recommended benefits in this application because
    1) it provides a thicker layer of protection between the axle and are new bushing
    2) The heavier gear oil takes up some of the slop out of the side gear which is the inherent manufacturing problem that causes all this, so the heavy gear oil helps take up some of that slack in the side gear and that also calms vibrations.
    smitty99 likes this.
  14. Apr 6, 2017 at 4:44 PM
    #234
    smitty99
    Scottsdale
    Just drained it all out, it took 1.6qts thereabouts
  15. Apr 6, 2017 at 4:50 PM
    #235
    ievko82
    WV
    Thank you.
  16. Apr 10, 2017 at 9:07 AM
    #236
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    Changed my diff fluid after I put it in and found a piece of the old bearing. Glade I did it right away.
  17. Apr 10, 2017 at 9:21 AM
    #237
    ievko82
    WV
    J7st took mine to the dealer. They said it was the tires and they rotated them. They acted oblivious to the problem. My bushing will be here tomorrow. I wonder if I should just forget the dealer and put the bushing in.
  18. Apr 10, 2017 at 12:20 PM
    #238
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    If I install the bushing do I need to drain and refill the diff oil? And are you guys using the ecgs recommended fluid type or the oem?
  19. Apr 10, 2017 at 12:22 PM
    #239
    smitty99
    Scottsdale
    I used the ECGS recommended 85w-140 Lucas brand.
    Yes you'll want to just drain it all out. It's less than 2 quarts (I think 1.6 is how much I used) BTW I believe all this is discussed on this page and the previous page.
    VA SOFTACO and peppinoss[QUOTED] like this.
  20. Apr 10, 2017 at 1:09 PM
    #240
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I'm glad you got that fixed Smitty. Weren't you going to wait until your howling differential was fixed before doing the lift? Did you just get tired of waiting?
    I wish I knew you were going to do the bushing. I'd have loaned you my bushing tool.
    I've installed 2 myself on previous trucks and have about 100k miles on them after the swap. No problems so far. I don't know about 500k but the part should last as long as you own the truck.
