Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Apr 10, 2017 at 10:25 PM
    #261
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    At least one member reported premature wear on the CV Axle after about 7k miles driving on the vibes. I wouldn't personally want to go much longer than that. YMMV
    breader3 and 1bad2k like this.
  2. Apr 10, 2017 at 10:30 PM
    #262
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    X2. Cheap enough fix to go ahead and just do it.
    breader3 likes this.
  3. Apr 10, 2017 at 10:58 PM
    #263
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I tried a slide hammer didn't work, so I made my own tool with some scrape laying around.
    mcharfauros, SilverII and GPsevinSixx like this.
  4. Apr 11, 2017 at 4:35 AM
    #264
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    Cool. That's what I'll do then, seems easy enough.
  5. Apr 11, 2017 at 8:46 AM
    #265
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    What is the OD of the needle bearing? I'm assuming you went just under that for the flat plate with the nut welded to it.
    Thanks
  6. Apr 11, 2017 at 8:53 AM
    #266
    smitty99
    Scottsdale
    Sorry just saw that I missed this question. I have not loaded it down or towed anything yet. However @Threerun did and he has plenty of feedback. There are some threads where he posted photos after hooking up a fairly heavy trailer with the lift installed. I'll have to search and see if I can find it. @GPsevinSixx may have some feedback there as well because I know he's done a few wheeling trips on his setup. We all have essentially the same except they're running Gen2 6112s and I run the 6112s for Gen3. The difference is not likely to be discernable.
    GPsevinSixx likes this.
  7. Apr 11, 2017 at 8:54 AM
    #267
    smitty99
    Scottsdale
    If nobody else responds, I do have digital calipers at home and can get your a measurement after 3pm PST.
  8. Apr 11, 2017 at 9:09 AM
    #268
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    what is this inserting tool people have mentioned?
    I just used a block of wood to tap the bushing in.
  9. Apr 11, 2017 at 9:14 AM
    #269
    smitty99
    Scottsdale
    Hiluxski likes this.
  10. Apr 11, 2017 at 9:16 AM
    #270
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    It always hits bumps stops when off pavement. Under 2" lift won't give you all that much clearance at static position between the bumpstops (Wheeler's & Timbren) to frame/ LCA, but they're 100% functional as it just engages earlier utilized as a compression damper. The stock bumpstops are hard and don't do as well as some of the aftermarket offerings when you get some articulation in the corners, especially at 10mph+.
    I haven't towed at all yet. At most, only had about 140 pounds of gear in the bed and 60 mph max on washboard roads and lots of MX whoops sections carved out in the California desert. Did bottom out a few times, but the bumpstops really help. I have the wheelers superbumps up front and timbrens (harsher) in the rear. I believe smitty went all superbumps in his truck.
    smitty99[QUOTED] likes this.
  11. Apr 11, 2017 at 9:23 AM
    #271
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    Thanks for the reply. I guess that's a bit of an improvement over factory. I've never had a truck that bottoms out like this one. Even unloaded with just a camper shell, I sometimes hit the bump stops on paved roads with my factory leaf springs. Just want to make sure I'm getting better rather than worse with the install of anything aftermarket.
    I think I'm still leaning toward replacing the springs entirely.
    GPsevinSixx[QUOTED] likes this.
  12. Apr 11, 2017 at 9:26 AM
    #272
    swimmer
    Tucson
    2016 TRDORAC4WD
    Thanks.
  13. Apr 11, 2017 at 9:27 AM
    #273
    GPsevinSixx
    Ros Angerus
    Probably a better option for you if you've got that shell on 100% of the time and carrying gear. Maybe go with some sumo or timbren stops before you fully commit to swapping the springs?
  14. Apr 11, 2017 at 9:27 AM
    #274
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I'm not really seeing a purpose for that bearing tool.
    Looks like all it does is provide something to hold while pushing in. Does it really help any?
  15. Apr 11, 2017 at 9:39 AM
    #275
    swimmer
    Tucson
    2016 TRDORAC4WD
    It pulls the bearing out. Watch the vendor's video if you don't understand.
  16. Apr 11, 2017 at 9:42 AM
    #276
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Is that the installer kit from East Coast gear for $44.95 ?
    Thanks
  17. Apr 11, 2017 at 9:56 AM
    #277
    GPsevinSixx
    Ros Angerus
    It's for install :) helps seat the bushing without distorting the shell or gouging the casing as it gets hammered into the machined hole it will live in.
  18. Apr 11, 2017 at 10:16 AM
    #278
    smitty99
    Scottsdale
    The superbumps are like little pillows when you bottom out! Wow major improvement from stock. I have them front and rear, Wheelers makes a set that goes with the All Pro Flip Kit. Perfecto!!! Highly recommend!
    ETAV8R and GPsevinSixx like this.
  19. Apr 11, 2017 at 10:17 AM
    #279
    swimmer
    Tucson
    2016 TRDORAC4WD
    I thought he was referring to the bearing removal tool.
  20. Apr 11, 2017 at 10:18 AM
    #280
    smitty99
    Scottsdale
    The multicolored box of "roller skate wheels" are the Bushing Install "tools"
    The Bolt and two metal plates (one short and one longer) are what you use to remove the Piece of Shit Needle Bearing. Use this first to remove. Then install new ECGS bushing with the pretty colored roller skate wheels :D
    I do not know exactly what the Bushing Installer Tool/Kit looks like that ECGS sells for $44.95 or whatever it costs. I only bought the removal tool for $60.
