Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Apr 12, 2017 at 10:30 AM
    #301
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    I've seen many people post in this thread about having to use a slide hammer or pry with some force to remove the CV axle from the diff. However, in one of the Gen2 threads about the ECGS bushing install it is mentioned a couple of times that the axle will pull out fairly easily if you get the circlip on the end of the axle orientated correctly before trying to pull the axle out. Basically the open end of the clip needs to be facing down, so apply some prying force against the axle, if it doesn't pull out push the axle back in the unload the circlip , rotate the axle about 1/6 of a turn and try again. Repeat until the clip is aligned properly and the shaft should come out with limited prying force.
    Has anyone applied this test technique recently with success?
    nartmot and VA SOFTACO like this.
  2. Apr 12, 2017 at 11:07 AM
    #302
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    That is how mine came out. Used a small pry bar with light pressure. My truck only had 15,000 miles on it tho
    GPsevinSixx and smitty99 like this.
  3. Apr 12, 2017 at 11:40 AM
    #303
    WZ KTM
    WZ KTM Member
    Colorado
    17 TRD OR
    OME/Dakar SPC LR 285/75/16
    That's the way I did mine. Just keep rotating and apply some force with a small pry bar. Once it releases put a mark on the axle and diff housing for reinstalling. Open end of the c clip was in the 6 o'clock position. When installing the axle I was able to pop it in with the palm of my hand.
  4. Apr 12, 2017 at 11:46 AM
    #304
    swimmer
    Tucson
    2016 TRDORAC4WD
    Thanks for confirming this. It just didn't seem correct to me that much force should be required to remove the axle.
    mcharfauros likes this.
  5. Apr 12, 2017 at 11:52 AM
    #305
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Yep. When it let go I was suprised how little force it took. I pried, rotated, pried, rotated, until I found the right position.
  6. Apr 12, 2017 at 11:54 AM
    #306
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Great tips ! On removing that axle , Thanks
  7. Apr 12, 2017 at 11:56 AM
    #307
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    It's one of those jobs that if you have to do it again it would take a fraction of the time.
  8. Apr 12, 2017 at 1:06 PM
    #308
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Yes, nearly all modern CV axles have this style clip retaining it. I've done close to a few hundred axles on all Japanese makes and all are the same. You're rotating the shaft around until the wire clip catches itself out of the detent and it just slides off easily. The prybar just keeps outward pressure on the inner joint housing, till it slides out. Don't forget to replace the seal.
    Also, be mindful of where that pry bar sits when popping it out. The CV axle bearing surface is pretty hard, but try not to scratch or gouge it.
    nartmot, VA SOFTACO and smitty99 like this.
  9. Apr 12, 2017 at 1:08 PM
    #309
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    :bowdown:
  10. Apr 12, 2017 at 2:50 PM
    #310
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    It's easiest to use a couple of garage door cables. Wrap them around the end of the cv going into the diff, then get them straightened out in a loop and use a mallot or 5lb sledge to whack the cable loop outward. Comes out first try every time.
  11. Apr 12, 2017 at 2:56 PM
    #311
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Do most ppl replace the seal? My truck has 5k on it, I figured as long as I don't damage it with the axle I should be good. Or is this foolish?
  12. Apr 12, 2017 at 3:00 PM
    #312
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    A seal is about $15. I'd replace just for the peace of mind 2nd it doesn't take much to damage it. Cheap insurance not to spend another half hour doing the job again for the seal lol.
  13. Apr 12, 2017 at 3:01 PM
    #313
    smitty99
    Scottsdale
    Better to have and not need it. Lots of times it gets torn up upon removal. It's $20....
    Good luck finding it if you have that shit all torn apart and then can't put it back together because you didn't buy a $20 seal...
    GPsevinSixx likes this.
  14. Apr 12, 2017 at 3:07 PM
    #314
    ievko82
    WV
    Thank you. Do you think most Toyota dealers stock this item? I didn't order it with my bushing. Are the seals the same as the 05 and up trucks?
  15. Apr 12, 2017 at 3:11 PM
    #315
    swimmer
    Tucson
    2016 TRDORAC4WD
    I think the purpose of rotating the axle with repeated attempts to remove the axle was to use as little force as possible in removing the axle, not because it was the quickest or easiest method.
  16. Apr 12, 2017 at 4:04 PM
    #316
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Gotcha. The first couple of times I removed it, I used the pry method. I didn't like how it left marks on the housing or the cv itself. The cable method puts for at two points 180° from each other. I think it does as well as any other method after trying plenty.
  17. Apr 12, 2017 at 4:05 PM
    #317
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
  18. Apr 12, 2017 at 4:31 PM
    #318
    SSM Taco
    SSM Taco Well-Known Member
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    Overland Bound #4340
  19. Apr 12, 2017 at 7:51 PM
    #319
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    What's the updated part number or TSB #??
  20. Apr 12, 2017 at 7:52 PM
    #320
    smitty99
    Scottsdale
    FailRev_1
