Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Apr 15, 2017 at 1:22 PM
    #361
    Bishop84
    Bishop84 Well-Known Member
    2nd gen TSB Part no# is same as 3rd gen part #. I tried it back in jan16 for giggles and got same results. Still haven't seen any other solutions for the issue other than the ECGS.
    I can now install them in 10 minutes :) I even have a cool spacer to protect the seal now haha.
  2. Apr 15, 2017 at 1:35 PM
    #362
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Any guess if it's what my issue is with all the side to side wiggle?
  3. Apr 15, 2017 at 1:38 PM
    #363
    Bishop84
    It's supposed to do that, all cv axle clips retain them with play like that for expansion and tolerances. In fact that's how I check to make sure they are installed correctly.
  4. Apr 15, 2017 at 1:48 PM
    #364
    Stig
    Brandon
    Ta no mo
    In and out, and side to side? Just seems a bit excessive. The passenger side is much tighter... Probably half the play.
  5. Apr 15, 2017 at 1:54 PM
    #365
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Believe passenger side uses a bushing for some reason. Can't remember where I saw that or why they'd vary.
    Stig[QUOTED] likes this.
  6. Apr 15, 2017 at 2:20 PM
    #366
    Bishop84
    Probably due to the housing extension rather than the axle sliding into the actual differential side gear like on the drivers side.
    All CV axles do it in one form or another.
    GPsevinSixx likes this.
  7. Apr 15, 2017 at 2:35 PM
    #367
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    If the needle bearings are already well worn, putting it in 4x4 might not make it go away.
    In and out is normal as already mentioned. The wiggling up and down, or front to back is what is causing the vibes. ECGS bushing will make it as tight, if not tighter, than the passenger side.
    CharlieCafe and Stig[QUOTED] like this.
  8. Apr 15, 2017 at 2:49 PM
    #368
    Stig
    Brandon
    Ta no mo
    Thanks. Guess I'll order and hope it solves the issue.
  9. Apr 15, 2017 at 2:49 PM
    #369
    Stig
    Brandon
    Ta no mo
    @iRideMTB
    CharlieCafe likes this.
  10. Apr 15, 2017 at 3:33 PM
    #370
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    Sounds like it's time for another "mod" day. :transformer:
  11. Apr 15, 2017 at 3:38 PM
    #371
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Can you please reply to all messages, every day on this board - just so we can look see your signature ?:bowdown:
  12. Apr 15, 2017 at 3:41 PM
    #372
    Stig
    Brandon
    Ta no mo
    He's the reason i turn my phone to landscape... :drool:
    GPsevinSixx and CharlieCafe like this.
  13. Apr 15, 2017 at 3:42 PM
    #373
    smitty99
    Scottsdale
  14. Apr 15, 2017 at 3:42 PM
    #374
    Stig
    Brandon
    Ta no mo
    I knew subbing to a third gen thread was a bad decision.
  15. Apr 17, 2017 at 11:47 AM
    #375
    jpowell1161
    jpowell1161 Well-Known Member
    Jake
    2015 Tacoma "Charlotte"
    Anyone have the removal tool ready to go to a new home? I will be doing the ECGS install shortly :)
  16. Apr 17, 2017 at 12:12 PM
    #376
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    NSFW....
    smitty99[QUOTED] likes this.
  17. Apr 18, 2017 at 11:26 AM
    #377
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    I plan on leveling out the front of my SR5 soon, and I'm going to do the bushing / seal replacement while I have it torn apart.
    So if anyone has one of the EGCS needle bearing pullers and knows how to accurately measure things, could you please give me the dimensions of the threaded needle bearing puller plate, the LWH dimensions of the cross bar and the thread diameter and length of the threaded rod, which from the picture looks to be ½-13 thd, as I want to make my own puller.
    If anyone has the puller, but isn’t capable of accurately measuring the puller parts, I would gladly pay the shipping and return postage for mailing me the puller so that I can measure the parts.
    I’m also going to machine up a piloted bushing and seal driver out of aluminum, which I have done many times before over the years for repair jobs.
  18. Apr 18, 2017 at 12:46 PM
    #378
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Lots of people mention removing the 35mm axle nut and the tie rod end in order to do this job. According to this thread neither of those needs to be removed. Granted this was 2nd gen but it shouldn't matter.
    https://www.tacomaworld.com/threads/ecgs-bushing-replacement-and-write-up-to-follow.472081/
    I've gotten all my parts/tools ready to go and I'll try the bushing replacement without removing those two items. Heading to Austin for the MotoGP race this weekend so hopefully I'll be able to get to this by the following weekend.
  19. Apr 18, 2017 at 6:31 PM
    #379
    swimmer
    Tucson
    2016 TRDORAC4WD
  20. Apr 18, 2017 at 6:36 PM
    #380
    smitty99
    Scottsdale
    Use a pvc coupler. Skim through here the guy says how
    https://www.tacomaworld.com/threads/drivers-side-diff-seal-nightmare.482851/#post-14753471
