Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. May 15, 2017 at 11:15 PM
    #501
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    I just used amsoil severe gear 75w90. I am considering swapping to severe gear 75w140 now for the front diff though.
    Taco1999[QUOTED] likes this.
  2. May 16, 2017 at 2:16 AM
    #502
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    You can rent a driver set from AutoZone that fits for nothing(just a deposit but you get it back)
  3. May 16, 2017 at 8:57 AM
    #503
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    I'm running the same Amsoil 75W-90 front and rear as I did before the bushing change. ECGS recommends the heavy gear oil for everything they do so I don't think its a specific recommendation because of the bushing and no one to my knowledge has ever presented any info as to why that would be the case. Use what you are comfortable with.
  4. May 16, 2017 at 9:07 AM
    #504
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Somebody here did explain the mechanical advantages of running the heavier gear oil due to going from bearing to bushing but I couldn't recall where to find the explanation. Don't recall if that came from ECGS or one of the resident folks who was a certified mechanic. I went with the ECGS recommendation.
  5. May 16, 2017 at 9:38 AM
    #505
    swimmer
    Tucson
    2016 TRDORAC4WD
    I'm certainly open to hearing/learning the advantages but I've not read anything credible and I think that includes the explanation post you are referring to. I strongly suspect that no matter what oil people choose to run we won't be hearing about any failures due to the oil.
    mikestaco17 likes this.
  6. May 16, 2017 at 10:01 AM
    #506
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    After thinking about it more, I decided to go with 75w-90 gear oil instead of the 85w-140, as the passenger side CV shaft uses a bushing and I haven't read of anyone on the forum having that bushing fail using either the factory 75w-85 gear oil or 75w-90 gear oil.
  7. May 16, 2017 at 12:42 PM
    #507
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I just replaced one that had a different seal than the others I have seen. Might explain why some people see leaks after replacing them. It was a stock FJ and the seal was seated down in the housing. Pulled it and was getting ready to install the correct Toyota seal and noticed they were different. I then pulled out my spare skf seal and it was the same as the new oem seal. the FJ seal had a much longer outer lip and the sealing surface itself was further out than the current oem ones. So I installed the new oem completely seated and it pissed fluid, installed skf flush and it was fine.
  8. May 16, 2017 at 2:35 PM
    #508
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Good question!
  9. May 19, 2017 at 2:51 AM
    #509
    bh867
    bh867 Well-Known Member
    idaho/utah
    tacoma
    arb bumper winches- xrc 8 front xrc 10 rear 2 lightforce 140's 40" led light bar Custom CBI built bed 4.88' and arb's front and rear tc long travel
    I just bought a 2005 bcsb trd sport. I have a constant vibration/hum, I have to check to see if it's in the wrong gear sometimes. The previous owner wasn't very good with tire rotations so they're a lil bit unevenly worn. I thought it was a wheel bearing when I bought it but they felt tight. It does it wether it's in 4wd or 2wd. Does this sound like it could be the needle bearing even if it does it in 4wd and 2wd? Could the tires really be causing this? They're definitely not worn correctly but I didn't think they were that bad.
  10. May 30, 2017 at 11:08 AM
    #510
    spencer2423
    spencer2423 Well-Known Member
    2016 TRD Sport
    did you DIY or have dealership install?
  11. May 30, 2017 at 11:28 AM
    #511
    hellaflushca
    hellaflushca @truck_norriz
    I was getting new suspension installed and just had them do it.
  12. Jun 1, 2017 at 11:38 PM
    #512
    12dcsport
    12dcsport Well-Known Member
    Pa
    17 DC OR
    Just had the dealer install my 3" lift on my 3rd gen. Went that route hoping they'll fight me less on warranty work. Anyway, I've got vibes now.... Has anyone had a dealer install the ecgs bushing? How was that process and what'd they charge you for it?
  13. Jun 2, 2017 at 12:54 AM
    #513
    Pax11B
    Pax11B Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    Pointless for me to really respond as I didn't have the dealership install my lift. Had a shop do it and figured I might as well do the Bushing as a safety net so the shop did the Bushing install as they did the suspension and didn't charge me at all for doing it. Probably cause they had 3 guys working on my truck.
    Mine was the first 3rd gen they have worked on and have never done or heard of the ECGS Bushing before but after they watched the videos and tutorials on ECGS they gave it a go and it came out great.
    Since you already have the lift installed by the dealer I honestly do not see why they wouldn't do the work. Idk if they warrantied their work on the lift, but if they did I don't think it should cost much if anything
  14. Jun 4, 2017 at 11:41 AM
    #514
    WILDPEAK
    WILDPEAK Well-Known Member
    Drew
    Rancho Cucamonga, CA
    '16 TRD OFF-ROAD
    LT265/75R16 WILDPEAK AT3W
  15. Jun 4, 2017 at 1:16 PM
    #515
    ScottyR
    Vancouver BC
    2016 DCLB TRD Sport
  16. Jun 4, 2017 at 4:40 PM
    #516
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    That's just what mine look like
  17. Jun 7, 2017 at 12:26 PM
    #517
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I give up, I've been trying to remove the CV shaft for over an hour with no luck using all of the suggested techniques mentioned here, so I'm going to give it one more shot in a little bit, and if still won't come out I'm just going to put it back together. WAPITFA :frusty:
  18. Jun 7, 2017 at 12:46 PM
    #518
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    Did you try the pry a little and if not. Push back in and rotate a little then pry again?
  19. Jun 7, 2017 at 12:47 PM
    #519
    Taco1999
    Jeremy
    Slidell, Louisiana
    try a long pry bar,or wraping a rope or cable around it then loop it and hit with a hammer
  20. Jun 7, 2017 at 12:48 PM
    #520
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    This is exactly why I just paid a shop to replace mine.
