Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Jun 16, 2017 at 11:10 AM
    #541
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Why did you use an oil with LSD additive when these trucks have no LSD?
  2. Jun 16, 2017 at 11:11 AM
    #542
    swimmer
    Tucson
    2016 TRDORAC4WD
    If you dig around this forum you will find guys with 100k+ miles on the bushing.
    ScottyR[QUOTED] and 1bad2k like this.
  3. Jun 16, 2017 at 2:24 PM
    #543
    L. I. Taco
    L. I. Taco Member
    2008 Double Cab, Long Bed, TRD
    Thanks for the replies Swimmer n Scott! Good to hear that bushing holds up.
    To Swimmer... The Owners Manual for my 2008 says rear diff only, requires 90W w/LSD additive.
    If that's NOT an LSD, then why does it bind up on low speed tight turns when 4 high is engaged? (for example, when turning or backing into a parking spot).
    Is it a full locker in 4WD?
    Please... "Esplane Lucy"!...
  4. Jun 16, 2017 at 2:26 PM
    #544
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    The binding is due to the differences in the turning rate of the front and rear wheels. If your truck is a sport it is called LSD, but it's not a torsion type diff, the limited slip is electronically controlled by the brakes.
  5. Jun 16, 2017 at 2:28 PM
    #545
    mlevinson
    mlevinson Well-Known Member
    Raleigh, NC
    2017 TRD Off-Road
    I believe the passenger side uses a friction type bushing, just like the ECGS bushing. I swear I've read that somewhere, which is even more bizarre as to why Toyota chose the needle bearing route on the drivers side.
    1bad2k likes this.
  6. Jun 16, 2017 at 2:29 PM
    #546
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    I've read the same, forgot to look when we had the passenger side cv out though.
  7. Jun 16, 2017 at 3:07 PM
    #547
    swimmer
    Tucson
    2016 TRDORAC4WD
    Sorry, since this is the 3rd gen section I assumed you had a 3rd gen.
  8. Jun 19, 2017 at 10:15 AM
    #548
    L. I. Taco
    L. I. Taco Member
    My truck is a 2008 Sport, and I see the separate brake circuits to each rear drum. On re-read of owners manual, it says "if" you have LSD rear, use LSD fluid... so am I to assume some other models DO have a true LSD, but not the Sports?
    And if so, why the speed difference front to rear? Is that caused in transfer case? And why only binding on turns, not backing in straight line?
    This is interesting "gearhead" stuff, so I really appreciate your, and everyone else's responses. Thanks!
  9. Jun 19, 2017 at 10:23 AM
    #549
    L. I. Taco
    L. I. Taco Member
    Hey, "Cartman"! (great character!) You are correct... if Toyota did one bushing, n one bearing, gotta wonder why.
    Just a quick reminder guys... the slide hammer pullers and bearing driver kits can usually be "rented" free of charge at the major parts chains. I'd suggest buying the bushing first, then taking it to store n make sure their kit components match up to bushing properly, before u start job.
  10. Jun 19, 2017 at 8:00 PM
    #550
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Hmm, I'm not sure why they have that in the manual unless parts of it cross over from different Toyota vehicles. I was under the impression that all LSD were electronically controlled. Yes the is in the t case because the front wheels spin a bit more while turning than the tears due to scrub radius and all that science lol. The tears take a short cut! This is also why it's important to run the same tire size between front and rear. The binding doesn't happen in an all wheel drive vehicle because their t cases are designed more like a true limited slip diff.
  11. Jun 19, 2017 at 8:07 PM
    #551
    L. I. Taco
    L. I. Taco Member
    Aaahh.... very interesting.
    There are no controllers of any sort on rear axle, so if LSD is "faked" with braking system, it has to be done at ABS valve level. Pretty common to traction n stability control systems these days.
    Thanks again!
    1bad2k likes this.
  12. Jun 19, 2017 at 8:46 PM
    #552
    AramsTRD
    AramsTRD Well-Known Member
    Aram
    North Hollywood
    2017 Tacoma Silver Sky Off Road 4X4
    6k LED headlights Baja Design Squadron Sport R fog lights CaliRaised Ditch Brackets w/ Baja Designs Squadron Amber Baja Designs Squadron Pro flush mount on Rear Bumper Kings 2.5 with Resi’s Front and Rear Icon Tubular UCA’s with Delta’s OME Dakars Leaf Springs Timbren U-Bolts Flips kit with Timbren Bumpstops Demello Offraod Front Bumper Smittybilt Winch9500lbs W/ Synthetic Rope TRD PRO Skid Plate for the front Pelfrey Mid, Rear and Gas Tank Skids Pelfrey Rear Bumper with Wilco Tire Carrier Welded on SCS F5’s 16x8 -25mm Wheels BFG KO2's 285 75 16 Prinsu Cabrac AllPro Rock sliders Import Equipment Red & Dark Grey Light Decals
    anyone selling the tool? i am in the la area
  13. Jun 23, 2017 at 2:54 PM
    #553
    Rogelio22
    Rogelio22 Get him a body bag! [TTC #030]
    Roger
    Sioux City, IA
    2018 Chevy Silverado 1500 Z71 Texas Edition
    Blank slate, ready to start
    Got my ECGS bushing and a replacement seal (bought on Amazon) on Tuesday and my vibrations since my lift are gone! Worked out great for me
  14. Jun 25, 2017 at 8:48 AM
    #554
    L. I. Taco
    L. I. Taco Member
    To "1bad2k"... something isnt addi g up here.... you questioned why i put lsd oil in when i didnt have a "true" lsd rear, and stated the "lsd" effect is accomplished with braking...
    so if thats the case, you are saying its a sraight up fully mechanical differential.. meaning no clutches or friction material. If so, then regardless of what oil I put in, it should not have created the slipping effect I experienced immediately after the change. Unless the t-case has lsd type clutches? All were changed at same time. ????
  15. Jun 27, 2017 at 6:49 AM
    #555
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    How was the install??
  16. Jun 27, 2017 at 7:32 AM
    #556
    Rogelio22
    Roger
    Sioux City, IA
    I had to pay a fab shop to do mine as I don't have the tools/space/and know-how to do it. It took less than a couple of hours though and they didn't charge me too much to do it either. The needle bearing broke into pieces when they removed it but the bushing went in and fit perfectly though.
    goose443 likes this.
  17. Jun 27, 2017 at 10:56 AM
    #557
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i got over 50k on my ECGS bushing.... no issues, no vibes, i expect ill never have to replace.
    mcharfauros and opentang like this.
  18. Jul 3, 2017 at 6:37 PM
    #558
    spencer2423
    spencer2423 Well-Known Member
    2016 TRD Sport
    Installed the bushing and all is well in my world. Will pass along the tool if anyone interested. $35
    stealthmode and mcharfauros like this.
  19. Jul 3, 2017 at 9:01 PM
    #559
    GECKO 01
    GECKO 01 Active Member
    Jeremy
    Arizona
    2017 TRDOR DCSB
    Bilstein 6112 and 5160 BFG 265/75/16 KO2 ECGS
    I took mine to ECGS to have it done and the guys there said it was warranted for the life of the truck. They told me if I ever had another problem to bring it back in and it was on them.
  20. Jul 3, 2017 at 10:24 PM
    #560
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Good info and that brings people confidence in their product.
    mcharfauros likes this.
