Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Dec 2, 2017 at 6:35 PM
    #621
    Miller1103
    Miller1103 Well-Known Member
    2017 trd or dc quickaand
    Ok maybe someone here can help with a concern I have with vibration. Just install 6112 front 5160 back Dakar leaf. Carrier bearing drop rear 3 degree axles shims and ecgs bushing. I have a vibration 18-28 in 2wd or 4x4. Truck has NOT been aligned yet doing it in the morning. Could this cause the vibration? Front is 2.75 inches higher right now. Back is level with front.
  2. Dec 4, 2017 at 10:28 AM
    #622
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Did you have vibes before the shims and drop kit? The drop kit could be contributing as well as the shims.
  3. Dec 4, 2017 at 11:36 AM
    #623
    Miller1103
    I added the 3 degree axle shim and cb drop during the install. I plan getting a angle gauge tonight. Maybe I should take the cb drop and test it first? Only takes a few mins.
  4. Dec 4, 2017 at 12:18 PM
    #624
    JoeCOVA
    Joe
    Colorado Springs
    While normally pre-planning is good you shouldn’t correct for vibes you may not have ever had. Can definitely check the the CB drop but I have a feeling it’s the 3 degree shims. Might need to put in 1-2 degree shims.
    In my case. I have a 3” lift and have no vibes with no CB and no shims. So it can vary greatly.
  5. Dec 4, 2017 at 1:42 PM
    #625
    Miller1103
    Not what I wanted to hear. But at least I know where to start. If accelerate little faster then normal 0 vibrations. The slower I accerate the more it vibrates.
  6. Dec 4, 2017 at 4:36 PM
    #626
    WorKinJoB
    WorKinJoB Well-Known Member
    Drew
    2017 Tacoma Sport 4x4
    OME lift, 887, Dakar packs 265 70 17 duratracs Snugtop GB sport
    Looking for the removal tool If anyone has it.
    soup222002 likes this.
  7. Dec 4, 2017 at 8:03 PM
    #627
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    Are most people replacing the cv axle seal while they are in there too? Also looking to buy or rent the tool to remove the old bearing. I'm located in Virginia
  8. Dec 4, 2017 at 10:53 PM
    #628
    JoeCOVA
    Joe
    Colorado Springs
    I’m sure some have not and some have. Personally, when it comes to seals I always replace with new. Not to mention I destroyed it during the removal process. Doesn’t hurt to replace it and if stock is still good, you have a spare.
    LoMa and soup222002[QUOTED] like this.
  9. Dec 4, 2017 at 10:56 PM
    #629
    JoeCOVA
    Joe
    Colorado Springs
    When I replaced the rear pack I researched and almost pulled the trigger on shims. Most shims were bolted with the pack and I didn’t want to have to pull the packs again to add shims.
    I read that shims contributed at times to vibes and decided not worth adding something that may not be needed. Luckily it worked out. That said I only considered 1 degree and 2 tops.
  10. Dec 4, 2017 at 11:05 PM
    #630
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    I did not change my seal. My truck was pretty new yet. It’s good. I keep looking down there for a leak though. I did buy a new seal at the time. Now it sits on my parts shelf just in case.
  11. Dec 4, 2017 at 11:16 PM
    #631
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Just got my bushing today and I think I wanna have a shop do this for me. By chance does anybody know a good shop around SLC, UT that can install this for me?
  12. Dec 5, 2017 at 3:59 PM
    #632
    raco.the.taco
    raco.the.taco Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    do you have the removal & install tool? or just the removal tool...
  13. Dec 5, 2017 at 6:57 PM
    #633
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Removal tool... sold. No install tool
  14. Dec 5, 2017 at 7:29 PM
    #634
    BeaverNation
    BeaverNation Well-Known Member
    mcharfauros likes this.
  15. Dec 6, 2017 at 1:41 PM
    #635
    SMBHooker
    SMBHooker Mag Beast
    2017 DCLB 4x4 TRD Sport MGM
    Is the CV Axle Seal required for the install?
    I'm having a shop complete the install and want to ensure I provide all the needed parts.
    Thx.
  16. Dec 6, 2017 at 1:45 PM
    #636
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I have both that I just purchased for my install hopefully this coming week. I will be looking to sell them both after my install if anyone is interested in both tools. PM me
    raco.the.taco likes this.
  17. Dec 6, 2017 at 4:44 PM
    #637
    WorKinJoB
    Drew
    It’s $20. It was worth it to not have to worry about it.
  18. Dec 6, 2017 at 5:51 PM
    #638
    Miller1103
    @JoeCOVA I thought I would give a update. Fix my vibration. Took out cb shim. Little better but still there. Then I realized like a moron I put axle shims in backwards :annoyed:. Turned them the right way drives like new!!:D
    raco.the.taco and JoeCOVA like this.
  19. Dec 6, 2017 at 6:50 PM
    #639
    JoeCOVA
    Joe
    Colorado Springs
    Very awesome. Glad you found the problem!!
    It happens to the best of us. I have a bad habit of changing seals and forgetting to pull out the old ones. Lol.
  20. Dec 8, 2017 at 12:55 PM
    #640
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    I have the removal tool for sale if anyone is interested. PM me.
