Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Dec 18, 2017 at 8:12 AM
    #661
    O_Nevermind
    O_Nevermind Well-Known Member
    2k16 TRD OR DCLB Barcelona Red
    Rain Guards and Bug Deflector.
    For those who just installed their lift, it might occur at a later time. I installed my OME Medium kit in July and the vibes hit hard last monday. Probably 2-3k miles on the lift. Should have done it while I was doing the lift.
    Edit: Does anyone know what socket mm size the axle nut is?
  2. Dec 18, 2017 at 8:52 AM
    #662
    WorKinJoB
    WorKinJoB Well-Known Member
    Drew
    2017 Tacoma Sport 4x4
    OME lift, 887, Dakar packs 265 70 17 duratracs Snugtop GB sport
    I changed mine without removing the axle nut. I just pulled it at the diff and moved it to one side. I already had the Lower Control arm, sway bar link ect off cause I was lifting. But I didn’t have to remove caliper, rotor, ect... pretty easy job.
    Silentshredr and Boneretreiver like this.
  3. Dec 18, 2017 at 8:30 PM
    #663
    BadgerBoy
    BadgerBoy Well-Known Member
    Brad
    Canton, Ga
    17' TRDORMT (Sold); 07' FJC
    https://www.tacomaworld.com/threads/my-17-tacoma-trdor-progression-most-of-it.673916/
    Any of you that have done the ecgs and no longer need the removal tool, I am interested in purchasing. PM me.
  4. Dec 28, 2017 at 9:45 AM
    #664
    Dt1524
    Dt1524 New Member
    2017 TRD O/R dcsb
    2.25" frt level 285 75R16 (33") duratracs
    Yes, the moment I drove off the lot after having a 2.25" leveling kit installed I noticed the vibration. Was still running the stock wheels/tires and it was very obvious. It did diminish when the truck got warmer so I wasn't able to replicate the noise for the shop. Now that it's cold out, it always there at 60 kph (40mph).
    Now that I've stuffed the 33's onto the truck the sound hadn't gone away or gotten worse.
  5. Dec 28, 2017 at 10:53 AM
    #665
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    has anyone installed the ECGS bushing to help with the vibs with out a lift?
  6. Dec 28, 2017 at 12:18 PM
    #666
    Miller1103
    Miller1103 Well-Known Member
    2017 trd or dc quickaand
    Yes. There has been cases where it has gone out without a lift installed.
  7. Dec 28, 2017 at 12:26 PM
    #667
    IPNPULZ
    going to be fun!
    I need to look into his as I have the buzzing vibes in the steering wheel at low RPM's
  8. Dec 28, 2017 at 12:29 PM
    #668
    IPNPULZ
    going to be fun!
    Yep...
  9. Jan 1, 2018 at 10:07 AM
    #669
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    I have the ecgs removal tool if anyone needs it. 45$ shipped
    2k4Taco likes this.
  10. Jan 1, 2018 at 10:09 AM
    #670
    Hodakaguy
    Hodakaguy Well-Known Member
    12 Tacoma/Vagabond Drifter
    PM Sent
    Hodakaguy
  11. Jan 5, 2018 at 8:23 AM
    #671
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Looking for the bushing removal tool if anybody has one laying around. Let me know what you want.
  12. Jan 6, 2018 at 9:20 AM
    #672
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
  13. Jan 6, 2018 at 10:45 AM
    #673
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    I had my bushing installed buy a Toyota master technician, who has installed over 180 of the bushings. I asked him about this and he said if your a heavy off road person and use your front diff a lot go with the 140w, otherwise the 75-90w is fine. I trust him and he has an excellent reputation as a Toyota 4x4 mechanic, 140 seams pretty heavy to me.
  14. Jan 6, 2018 at 2:46 PM
    #674
    2k4Taco
    Swanny
    Fleming Island, Fl
    What fluid did you end up using?
  15. Jan 6, 2018 at 3:48 PM
    #675
    2k4Taco
    Swanny
    Fleming Island, Fl
    What lift did you end up going with?
  16. Jan 6, 2018 at 3:57 PM
    #676
    2k4Taco
    Swanny
    Fleming Island, Fl
  17. Jan 8, 2018 at 1:49 PM
    #677
    Tedward
    Tedward Well-Known Member
    DMV/N. VA
    2016 DCSB TRD Sport 4x4
    Too many to list...
    Anyone have the removal tool they'd part with? Located in DC - DMV area.
    After reading the entire thread, think I'll be doing this with/just ahead of new suspension (between 5100s and 6112/5160)... Too many positive testimonials not to spend the extra $80 for bushing, seal, and peace of mind.
    Replaced the suspension among other things on my old TL-S but never messed with a CV axle before (luckily I guess). Nervously excited...
    2k4Taco likes this.
  18. Jan 8, 2018 at 2:27 PM
    #678
    2k4Taco
    Swanny
    Fleming Island, Fl
    Hey bro do you still have the packaging for the seal? If so what was the part number?
    BlueFalconActual likes this.
  19. Jan 8, 2018 at 3:50 PM
    #679
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    I had the same problem. Slidehammer axle puller from Autozone popped it right out. Had to use a 2x4 to pop it back in.
  20. Jan 9, 2018 at 6:20 PM
    #680
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    In the video on ECGS's website, they mention that the ARB front locker uses a busing rather than the needle bearing. Does anyone have first hand knowledge of this? I'm looking to do the 4.88 gears and an ARB locker, so curious if locker takes care of the needle bearing issue.
    jomopdx likes this.
