Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Jan 16, 2017 at 3:33 PM
    #61
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Anyone have a removal tool I could pay shipping on to and from?
  2. Jan 16, 2017 at 5:23 PM
    #62
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    Put an ECGS bushing in 100 miles ago and vibes are completely gone. Well worth it.
    BCJake[OP] likes this.
  3. Jan 16, 2017 at 5:29 PM
    #63
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I should have mine back any day now since I saw in another thread that the guy I loaned it to is done with it. No definitive ETA though.
  4. Jan 16, 2017 at 5:34 PM
    #64
    Haikin
    Haikin Well-Known Member
    Anyone have a link to good tutorial for removing the CV axle in order to do the ECGS bushing install?
    Thanks
  5. Jan 16, 2017 at 5:44 PM
    #65
    fdbyrne
    Missouri
    The process is exactly the same for 1st, 2nd, and 3rd gen Tacomas and at least 3rd and 4th generation 4Runners. There are a lot of YouTube videos. Don't limit your search to only 3rd gen Tacomas.
    I found that the best way is to get a really long flat head screwdriver. Long as in 18 to 24 inches and a BFH. There are lips on the inner joint that can put the tip of the screwdriver into and hit with the BFH. If it doesn't pop out, turn the axle a quarter turn and repeat.
    It'll pop right out.
    That method has worked far better for me that using a slide hammer and you can get both the screwdriver and hammer cheap at Harbor Freight.
  6. Jan 16, 2017 at 6:15 PM
    #66
    Haikin
    Thanks I will use this method. Just a tad nervous ripping apart the front end of an almost brand new vehicle. But it seems like a lot of folks here have had great success with after the get rid of that damn needle bearing.
  7. Jan 16, 2017 at 6:31 PM
    #67
    Hautian
    I had never pulled a CV before and was able to get it done by myself but it took longer than expected. I would recommend having someone else to help if possible and make sure you have all the tools ready. I had to buy a large socket to get the new seal started.
  8. Jan 16, 2017 at 7:20 PM
    #68
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    Where did you get it done and what was the cost? im in so cal and looking for a good guy to install this for me
  9. Jan 17, 2017 at 12:04 PM
    #69
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    I just got my ecgs bushing installed, made a big difference. Little to no vibration if any, must be the road. Sounds smooth, no more rumble in an intermittent motion. A must for all lifts or modified suspensions!
    BCJake[OP] and fdbyrne like this.
  10. Jan 17, 2017 at 12:44 PM
    #70
    fdbyrne
    Missouri
    If you're replacing the seal as well (which is smart) I found that an inline PVC coupler that's meant to joint two 2" sections of PVC pipe has exactly the right diameter to push a seal in without tearing up the lip and generally runs less than $1 at the hardware store.
    I got lucky and had one on hand.
    Fishallday, [KD] and TACO_83 like this.
  11. Jan 17, 2017 at 7:18 PM
    #71
    flash5twelve
    flash5twelve Well-Known Member
    Greg
    2016 TRD Off Road DCSB 4x4
    My 2016 with 10,000 miles started with the front end noise as soon as I installed an Icon Stage 3 lift. I am geographically fortunate to live close enough to ECGS that I drove up to Raleigh today and had them do the bushing install.
    They were friendly and had the job done in about an hour. The cost of the repair was $160 plus tax.
  12. Jan 17, 2017 at 7:26 PM
    #72
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    How does this issue present itself? What does it feel like/what are the symptoms?
  13. Jan 17, 2017 at 7:37 PM
    #73
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    It's basically a design flaw from Toyota. They will deny it, but the needle bearing on the drivers side (none on the passenger) vibrates at some point pretty bad from lifting/changing the drive line cv angle. It will vibrate intermittently or in a cycle and eventually stop at highway speeds. It tends to get worse in cold weather. Long term mileage will eventually chew up your cv shaft. This is an easy and long term fix. Toyota dealerships have been known to even replace the bearing with the EGCS bushing with warranty. Why hasn't Toyota fixed this stupid design???? Most people who aren't educated think it's an unbalanced tire .
    I don't know why Toyota decided to put a needle bearing only on the drivers side, but ECGS makes a bushing that eliminates the factory bearing. It's very easy to install, but most shops have no idea about this issue or how to install it. If you show them a video they will be like "oh yeah that's cake!".
  14. Jan 17, 2017 at 7:41 PM
    #74
    tacoflavoredkisses1
    Gotcha.
    So does is sound like a high freq vibe? Do you feel it ? An unbalanced tire kind of has a wobble feel to it and a shimmy in the steering wheel.
    The only reason I'm asking is because I'm about to go in for my 20k service.
  15. Jan 17, 2017 at 7:47 PM
    #75
    Filthy13
    Filthy13 Well-Known Member
    2016 DCSB 4x4
  16. Jan 17, 2017 at 11:37 PM
    #76
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    Would a diff drop prolong this issue? Sounds like no matter if your liffited or not it's gonna take a dump eventually definitely don't want needles in your spider gears. Also anyone have high miles on the ECSG bushing I'm kinda afraid to do mine just seems like Toyota used a needle bearing there for a reason and going to a solid bushing I'm worried if it may damage the axel shaft of carrier. How does it get lubricant from the diff housing is it bathed in oil?
  17. Jan 18, 2017 at 4:18 AM
    #77
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    IMO it sounded like cupped or feathered mud terrain tires when slowing in a corner.
  18. Jan 18, 2017 at 9:42 AM
    #78
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Those are useless in my opinion. So many members have the ECGS bushing and some reported 100,000 miles or more on the bushing with no issues. I haven't seen one negative thing about the bushing.
  19. Jan 18, 2017 at 9:45 AM
    #79
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Similar, mine sounded like a humming noise in 1 full second intervals. Actually it felt and sounded like when you drive on the side of the highway shoulder and hit the strips that vibrate like crazy to wake you up. Just a tad bit less noisey/less vibration.
    Pportera likes this.
  20. Jan 18, 2017 at 9:46 AM
    #80
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    No high frequency vibe, yes you feel it on the driver's floorboard, some in the pedal, some in the steering wheel.
    Tends to go away when warmed up, you may have the service tech come back saying "unable to replicate"
