Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Apr 5, 2019 at 10:58 AM
    #921
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    RPM Garage in Monrovia quoted me $200. I've had work from them done before. Good peeps.
    Fuerte likes this.
  2. Apr 11, 2019 at 8:21 PM
    #922
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Not sure if this is the rite place for this but I’m getting vibration after installing fox 2.5s and UCAs. Only between 15-25mph and it does NOT go away in 4hi. It does seem to be worst when it’s cold though, I’ve had a alignment done, I’ve torqued everything to spec. Could it still be the ecgs bushing just hiding from me? Maybe a wheel bearing?
  3. Apr 11, 2019 at 10:49 PM
    #923
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    Have you done the dif drop?
  4. Apr 12, 2019 at 12:46 PM
    #924
    714reyesj
    Danny
    Orange County, CA
    From what you are explaining, I don't think the needle bearing is causing your issue. I didn't immediately get vibs when I installed my King and Camburg UCAs on stock leafs. But, I did immediately start noticing vibs once I installed my Icon RXT leaf pack. I'm pretty sure I'm going to need some shims to fix the vibs. I'm getting the ECGS bearing installed tomorrow not necessarily for the vibs I'm getting, but more so because I know it's going to need replacing eventually.
    Russty__[QUOTED] likes this.
  5. Apr 25, 2019 at 11:06 AM
    #925
    tacoburn327
    tacoburn327 Well-Known Member
    Todd
    Vancouver, WA
    2017 TRD Off Road Access Cab
    I just looked into this at Toyota of Vancouver (WA). They too sell the ECGS bushing, however, they won't replace it under warranty, they want $400. They said they would put in a new needle bearing under warranty but I declined because it wouldn't do any good. If Toyota dealers are stocking this part they obviously know it's a problem but Toyota is not letting them fix it under warranty? That's BS. Better yet, why don't they just fix the well known problem from the factory!
    Heavily Meditated likes this.
  6. Apr 25, 2019 at 4:53 PM
    #926
    treimche
    treimche Well-Known Member
    Fargo, ND
    They would rather replace entire front differentials apparently.
    tacoGR and dfanonymous like this.
  7. Apr 25, 2019 at 5:59 PM
    #927
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    never seen it go bad on a stock truck..
  8. Apr 25, 2019 at 8:36 PM
    #928
    treimche
    Fargo, ND
    Pretty sure there's either a recall or TSB for replacing the entire front diff due to vibrations related to the needle bearing.
  9. Apr 25, 2019 at 8:49 PM
    #929
    nartmot
    nartmot Well-Known Member
    I did mine a couple weeks ago. Wow! What a huge PIA getting the cv out. I tried all manner of prying, rotating, and pounding to get it out. Eventually the sledge hammer and steel cable trick was the only thing that did the job. The c clip was mangled, and it gouged the spider gear slightly on the way out. I replaced the c clip with a new one of course. Also changed the front diff fluid right away in case there was any metal bits floating around. Glad I did because the magnetic plug had a good amount of metal shavings on it. Truck is running great with the new ADS extended travel lift.
  10. Apr 26, 2019 at 3:08 AM
    #930
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Newb question... does the ECGS bushing only get installed on the drivers side? or both sides?
  11. Apr 26, 2019 at 6:04 AM
    #931
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Jut drivers side
    Red18Taco707[QUOTED] likes this.
  12. Apr 26, 2019 at 6:12 AM
    #932
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Any guys in stock Taco’s ever get this vibration? I had it in my 2nd Gen, so I am familiar with the vibe. It was lifted though. Every once in awhile I could swear I feel it in my 18, could be in my head though or the road it causing it.
  13. May 28, 2019 at 7:18 PM
    #933
    Tacoma Outdoors
    Tacoma Outdoors Well-Known Member
    Austin
    Denver, CO
    2019 Tacoma TRD OffRoad Cement
    Does anyone have the removal/install tool they would want to part with? Looks like I will be changing my bearing out shortly....
  14. May 29, 2019 at 9:16 PM
    #934
    RAEmmons
    RAEmmons Member
    Rich
    Stephenville, TX
    2015 TRD Sport
    OVtune Bilstein 5100's Supreme Suspension Jumper LED
    anyone in central Texas area had this done and can recommend shop or have tools for sale?
  15. May 30, 2019 at 7:56 AM
    #935
    RAEmmons
    RAEmmons Member
    Rich
    Stephenville, TX
    2015 TRD Sport
    About to do a few more test to see if i need clamshell bushing... my vibrations were noticeable both before and after lift 2.5" Bilsteins front and SS 1.5" blocks on back, but maybe more so after.
    Vibrations: can be felt coming through the steering wheel and seat/ console... they come in consistent wave like patterns every 5-10 seconds, more noticeably around 60-70 mph. feels like motor shuttering slightly but annoyingly because it comes and goes.
    Tried turning off the AC thinking it may be it not sure i noticed much of a difference.
    Based off the previous replies... sounds like this could be the culprit. What do y'all think?
    Couple of notes:
    1) Tires were balanced and aligned.
    2) i did not drop the differential yet, is it necessary with the slight lift i have?
    3) can any body recommend an experienced shop in Texas (central or DFW)?
  16. Jun 26, 2019 at 7:40 PM
    #936
    MundaneFace
    MundaneFace Well-Known Member
    2017 TRD OR
    Just installed my BP51 kit on my 3G, and get intermittent "pulsing" vibrations/slight grinding now, after alignment, but only while warming up and goes away in 4Hi. It seems like it the vibrate fades in, vibrates for 2-3 seconds, then fades out for 10 seconds when cruising between 10-30mph. It does seem to increase with speed, but just puzzling why the vibration is almost "harmonic"? No diff drop, and overall, my lift settled considerably with winch/bumper/sliders on, CV angles aren't too extreme.
    I'm going to do the bushing ASAP, but curious if the "pulsing" is part of the normal symptoms or if there might be something else going on?
  17. Jul 2, 2019 at 8:16 AM
    #937
    Jubes13
    Jubes13 New Member
    Alberta
    2018 blue Tacoma trd sport manual trans
    Hey so I have a 2018 trd sport 6 speed manual. I installed a 3 inch lift and noticed a vibration that happens for 1-2 seconds then stops for about 3 seconds it stays at this interval regardless of speed. It stop when I switch it to 4WD. My main concern is that I’m supposed to drive the truck across Canada from Edmonton Alberta to newfoundland. Roughly 6000 kms. Not sure if I am going to be able to get the bushing installed before I make the trip. Wondering if it would be fine to make the trip one way. Also going to have a motorcycle in the back (not sure if weight will make much of a difference) thanks for any help and suggestions in advance. Hoping it will be fine lol
  18. Sep 3, 2019 at 7:50 PM
    #938
    Tcgator
    Tcgator Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
    Need the Needle bearing puller tool for the swap! Anyone have one they would want to pass on or sell?
  19. Oct 13, 2019 at 12:28 PM
    #939
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    yeah, why is that tool $45 bucks? its a threaded rod, piece of 1/4in sheet metal and a nut. Fuck, I might just make one myself. Would probably only cost $7 and 20min worth of work.
    Taco 6x6 likes this.
  20. Oct 24, 2019 at 7:03 PM
    #940
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    I did the install two weeks ago and it went as planned, cussing jammed fingers, dropped a hammer on my face while trying to get the axle out. Basically the usual issues as previously described in this thread. But it all went back together just fine.
    I noticed now I'm leaking fluid from near the seal. And I do remember installing the seal all the way in. I guess I I didn't read the part about installing flush. So now I've ordered another seal and I'll be doing this all over again.
    I encourage anyone with questions to read this whole thread while you're waiting for parts to arrive.
    My only tip is when installing the CV axle, rotate the c clip so that the open end is facing down. And you can put a spot of grease on the clip to keep it centered on the shaft. Once you get that clip past the threshold it slides in easy using the hammer and screw driver method.
