Front Diff Vibes ECGS bushing fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BCJake, Dec 13, 2016.
  1. Jan 18, 2017 at 10:36 AM
    #81
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    This is a good explanation of what I am feeling/hearing. The roads have been un-smooth with ice these last couple of weeks so haven't been able to confirm the vibs go away in 4WD. Looks like I'll have to upgrade the bushing. Might as well, right?
  2. Jan 18, 2017 at 12:41 PM
    #82
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    Do it. I debated about the bushing, but read nothing but good reviews. If it goes away in 4WD then it's definitely the needle bearing.
  3. Jan 18, 2017 at 12:59 PM
    #83
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Between my 1st gen Tacoma and my 4th gen 4Runner I've racked up about 100,000 miles on the bushings and they've held up well. Like pointed out above, there's nothing but good reviews and not much that can go wrong if properly installed. It's a pretty easy mod to do yourself if you have the tools and a few hours to spare.
  4. Jan 18, 2017 at 1:04 PM
    #84
    GTM
    GTM Member
    SW Pa.
    2016 TRD DCOR
    I just received my lift today from Headstrong. I read this post and ordered the bushing to be installed with the lift.
    Marcoc and 0311K1LL like this.
  5. Jan 18, 2017 at 2:06 PM
    #85
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    It's a must have, the needle bearing eventually goes out randomly.
  6. Jan 20, 2017 at 3:29 PM
    #86
    ForestFever1
    ForestFever1 Well-Known Member
    Ted
    Mississippi
    2017 Quick Sand TRD4X4 0ffroad
    Bilstien coilovers Toytec AAL w/fox 2.0's Sway bar relocate Carrier bearing drop ECGS needle bearing delete 285/75/16 Dick Cepek Extreme Country
    Just finished talking to my dealership. They played dumb as if this was never an issue after I brought it up that my research has found this to be a known problem.
    They said try to go through corporate or else they would just replace the needle with another one.
    Whatever. Getting it done locally I guess.
    Just hate I have to wait till next Tuesday to get it. Then I have an appointment the following Tuesday. Ugh I hope my trip to Huston and back doesn't mess it up more before I can get to it.
    Went ahead and got the install& removal tool, and seal.
    Third gen here, 6k, 2 inch front level.
  7. Jan 20, 2017 at 3:31 PM
    #87
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Plenty people were lifted for 20k plus miles with the noise and no damage. You will be fine.
    Marcoc and ForestFever1[QUOTED] like this.
  8. Jan 20, 2017 at 3:32 PM
    #88
    ForestFever1
    Ted
    Mississippi
    Oh thank goodness.
  9. Jan 20, 2017 at 3:53 PM
    #89
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    LOL, replace with a new needle bearing and have that one go out again real quick.
  10. Jan 20, 2017 at 4:05 PM
    #90
    lloverso
    lloverso Active Member
    Pa
    2018 Tacoma TRD Off Road
    ProComp 3/1 Nitro Level Kit Diff Drop Spacer 17x9 Method 312 -12 Offset 285/70/17 Nitto Terra Grappler G2
    Had the ECGS bushing installed today. Also had the TSB for the new leaf packs, steering damper as well as the TSB to plug the lower control arm holes. The good news is the vibration is GONE!!!! The truck rides really smooth so far and the horrible vibration I had is gone. The bad news is since they installed everything at once I can't say for sure which actually fixed the vibration. If I had to put my money on one it would definitely be the ECGS bushing for sure!! I highly recommend upgrading to the bushing.
    0210 likes this.
  11. Jan 20, 2017 at 5:11 PM
    #91
    ForestFever1
    Ted
    Mississippi
    Sounds like a great idea right?! :der::goingcrazy:
    Lookin forward to a new lift and a no rumble ride. Patience is so difficult right now. :boom:
  12. Jan 22, 2017 at 12:29 PM
    #92
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    Did mine this weekend. Vibes are gone and its back to a quiet from end again. For those of you thinking about doing this yourself I just want to point out that you will basically destroy the needle bearing getting it out of there.
    Make sure you use a magnet to get the shards out of the housing before re-installing the axle. Follow the ECGS instructions on the video they made and you'll be fine.
    ready6delta and EB Group like this.
  13. Jan 22, 2017 at 1:27 PM
    #93
    ForestFever1
    Ted
    Mississippi
    It felt lame paying for the removal and install tool, but after seeing how easy it is to what seems like shatter that POS, guess I'm glad I did. Dude at A1 gear will hopefully appreciate it lol.
    Did you get their tools or use what ya had?
  14. Jan 22, 2017 at 1:34 PM
    #94
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Put it in 4wd and drive it. If the noise goes away, it is most likely the bearing. Also, if you lifted with an AAL or new springs, you probably need axle shims and a carrier bearing drop. Block lifts provide the necessary angle change that the axle shims provide. Carrier bearing drop is a trial and error method I found. I got replacement bolts that were longer and used a combination of washers to get the driveshaft back into alignment.
  15. Jan 22, 2017 at 1:59 PM
    #95
    flash5twelve
    flash5twelve Well-Known Member
    Greg
    2016 TRD Off Road DCSB 4x4
    Thanks! Already had the bushing installed by ECGS. My noise and vibration is gone. So far no new noises or problems with the rear end, but I'll keep an eye and an ear on it for problems with rear driveshaft alignment.
  16. Jan 22, 2017 at 3:48 PM
    #96
    99superduty
    I used the tools...there is a set going around.
    ForestFever1[QUOTED] likes this.
  17. Jan 31, 2017 at 1:10 PM
    #97
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Been feeling the same random vibrations that you guys are mentioning here. Cyclical, comes and goes, especially noticeable at around 70kph. Also felt the rumble sensation under braking here and there.
    Had the All Pro Expedition leaf pack installed today and that seems to have made the vibration much more pronounced. Got the truck booked in for Thursday to have the ECGS bushing installed and alignment done. Fingers crossed!
    Joe23 likes this.
  18. Feb 1, 2017 at 4:17 PM
    #98
    ForestFever1
    Ted
    Mississippi
    I just got home after doing mine. THE VIBE IS GONE! I'm so happy.
    If anyone wants the tools I got both the pieces, the uninstall piece and the tool set for instal.
    flash5twelve and 0210 like this.
  19. Feb 1, 2017 at 5:22 PM
    #99
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    are any of you running oil different than the Lucas 85W140 non-synth that ECGS recommends?
  20. Feb 1, 2017 at 5:33 PM
    #100
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    What trucks have a TSB out for new leaf packs and steering damper?
